L67 woes...
[video=youtube;ZCnYiJBN6k0]
I just bought this car and I know nothing about 90*s
Help me out here
Either supercharger coupler or spun bearing! Lol!
Hope for the first one!
But don't take my word for it I'm not 100% sure
Take the supercharger belt off and try again. If the noise goes away, its the supercharger. If it doesn't, you're screwed.
I put my life on this, Its not the supercharger ;) you spun a bearing. And Or threw a rod.
Ask me how i know! its only my 2nd one!
Video doesn't work
take the SC belt off and try again. but that sounds like a lower end has totally left the building.
Yeah I haven't heard a supercharger coupler sound that bad...sounds like it's teh motor :confused: How'd you get this car?
Yeah sorry buddy but thats exactly what my blazer sounded like before she self destructed.
Bought it.
can I use a na 3800 bottom end?
And it will be faster with a 3800 Bottom end. Make sure to get some mods if your going to run stock pulley on a N/A bottom end
Dp, u-bend delete, 104 plugs, CAI, Ported front and rear mani, colder t-stat. and a tune. Then you Might be safe with the stock 3.8
Like what?
IIRC, you're gonna want at least the mods that you need for a 3.4 pully'd car with a stock lower compression bottom end... Mods like Cold air intake, u-bend delete, colder plugs, 160 or 180 stat, and a good tune.
Ported stock shit is a waste of time. Do the t-stat, u-bend delete and intake first and get a tune as soon as you can. At the least, scan for KR as soon as you put it together.
God I would love to put you in the passenger seat of the Regal to prove you wrong. I picked up a LOT of power by porting the heads.
I think he meant with the manifolds, which is true haha.
yeah i did mean manifolds. I was just trying to reduce KR on the cheap.
Im frustrated tonight because I was hoping I could just drop the oil pan with the engine in the car, but it doesn't look like thats going to happen.:mad:
good luck with that one without dropping the subframe.
However from the sounds of it.... I would not even bother trying to replace bearings. that lower end sounds hammered.
