need ub3 plug adapter for 94 cutlass
i have looked at the threads and cant find who if anyone sells the ub3 adapter for the cutlass. would like to purchase one if they are being made
what exactly do you mean by adapter? like a plug with the UB3 male plug on one side and a female plug on the other for the stock harness? that shouldn't be too tough to make...
stockgp did that.....
however, if you can solder, I would twin the connector, which means you splice the wires from the ub3 cluster to the wires going to the original cluster in your car. this leaves you with an either/or choice in the event you need to change clusters again, or diagnose problems.
also, the airbag and security lights are not included in the pre 94 cluster, so you should somehow figure out a way to add them so you know if you have other system issues... ESPECIALLY THE SECURITY LIGHT.
Edited by Crazy K
i wonder if the correct pulse divisor is identical....?
I bought mine fom stockGP and just added 2 wires fr airbag and security, no regrets here
