Myotis1134 Posted May 8, 2010 Report Posted May 8, 2010 Ok, got the sub-frame from Wasilla, going to clean it up- maybe POR-15 it. Does anyone know if there is a write up on the bushings? I'd like to stick some polyurethane in there, as the vibration-transfer shouldn't translate too badly, and the added stiffness should be an improvement. I just want the size of the bushings, otherwise I'll just measure off of the good side. I've browsed the stickies for poly-bushings, but they all seem to be for suspension. Quote
19Cutlass94 Posted May 9, 2010 Report Posted May 9, 2010 As far as I know, no one makes poly bushings for our engine cradle. I would just use regular brand new ones, I dont think theres very many options here. Quote
RobertISaar Posted May 9, 2010 Report Posted May 9, 2010 DIY poly bushings? http://www.jdmuniverse.com/forums/how-tos-tutorials/53723-diy-polyurethane-motor-mounts.html not sure if you could apply the principle here though... Quote
mfewtrail Posted May 9, 2010 Report Posted May 9, 2010 Does anyone know if there is a write up on the bushings? http://www.w-body.com/content.php/195-1st-gen-subframe-bushing-replacement Just for future reference: The main page http://www.w-body.com has writeups under technical info, common problems, etc. for various things. Alternatively, you can browse through the FAQ section on the forum to find other writeups/common issues that are covered there. Quote
White93z34 Posted May 9, 2010 Report Posted May 9, 2010 yeah presently our only option is new rubber ones. I have the gm part numbers listed in the parts number thread Quote
19Cutlass94 Posted May 10, 2010 Report Posted May 10, 2010 Just to let everyone know, NAPA started carrying these as well. part # 650-4111 Quote
Myotis1134 Posted May 11, 2010 Author Report Posted May 11, 2010 right on. so rubber for now, possibly use the new rubber ones as a mold for polys. Quote
