jayman Posted May 2, 2010 Report Posted May 2, 2010 hey guys. well bad news about my cutlass.. pink wire runing from ecu to the coil fried my entire harness.. every plug and every join fused together... so.. i believe the motor is fine and all the parts except the coil module and the ecu. and of course the harness.. so instead of using another LSS harness and jimmy-rigging this thing together, what harness am i looking for here?? and also if anyone has pictures of what pins need to be switched on the firewall plug that would be great as well ive tried to contact the guy i was refered to for teh already modded harnesses but his email no longer exists or there is an issue with it. again its going from 3800 series 2 supercharged to my 94 cutlass Again i appreciate all the help Quote
slick Posted May 2, 2010 Report Posted May 2, 2010 IIRC, a 1997 or 1998 Monte Carlo or Lumina 3800 harness is the most desired for this application. Quote
terryk2003 Posted May 2, 2010 Report Posted May 2, 2010 have you checked out http://www.l67swap.com/ ?...you should be able to get the info you need from them. Good Luck Quote
RobertISaar Posted May 2, 2010 Report Posted May 2, 2010 IIRC, a 1997 or 1998 Monte Carlo or Lumina 3800 harness is the most desired for this application. 97 was still LQ1, but 98-99 is what you are refering to IIRC. Quote
jayman Posted May 2, 2010 Author Report Posted May 2, 2010 thanks guys, i will see what i can find tommorow. can anyone get the wiring info i need to switch pins around? Quote
Octavarium454 Posted May 2, 2010 Report Posted May 2, 2010 I got a Monte Carlo harness that you could use. Came from a 98 3800 and I bought it from Milzy Motorsports about a year ago. http://www.w-body.com/showthread.php/46097-FS-98-Monte-Carlo-3800-Harness Quote
White93z34 Posted May 2, 2010 Report Posted May 2, 2010 didn't we tell you to just use the proper harness in the first place just givin ya hell man! however i know DigitalOutsider has a 98' MC z34 L36 harness that he might be willing to unload. Quote
jayman Posted May 3, 2010 Author Report Posted May 3, 2010 ya your right... ha ha ha.. just when you think your a smart ass and can figure it out.. your baby catches on fire lol Quote
