maf cleaning
how do you clean a maf is there a method to it or just take it out and spray it with maf cleaner
also my mechanic/neighbor was saying dont clean it it will ruin is this true or the typical bs that he is normally full off
Go and spray it, just be careful with the sensors. Just make sure its completely dry before you put it back in. And you should be fine.
Just spray with MAF cleaner. DON'T touch or scrub the innards with your fingers or anything else for that matter.
MAF cleaner dries in seconds.... that's not much of an issue
not to mention the MAF will burn it off quickly anyway...
Are your fuel trims + or - 10% or less with correct B1S1 O2 voltages??
If so, then dont mess with your MAF. Theres noting wrong with it. A dirty MAF will always through off fuel trims and/or B1S1 O2 voltages.
Any time anything ever touches a MAF, there is a risk the element can be damaged, they are more fragile than you might think.
