BXX Posted April 27, 2010 Report Posted April 27, 2010 (edited) Gen 2 Aluminum Rear Knuckle and Brake Upgrade This is the definative and step-by-step how-to on how to upgrade your Gen 1/1.5 W-body. Rob (Venom) and I made sure to get good pics last night so you know what your looking at. Meaning even a Noob should have ZERO issue doing this. There is a bit of a prerequisite however, if you have a Gen 1, you must have rear coilovers! Gen 1.5 already has these so there is no issue with the missing leaf spring perch on the knuckles. For the non-believers, there is indeed a difference. For starters, you drop around 10lbs per side (Havent weighed them yet) , you get rear brakes with a better caliper that isnt known to seize up (mainly the slides) like the 88-93 and 94+ setup, and later down the road, if you wanted to upgrade to larger rear brakes, there are known aftermarket options out there. Also, it is not known if the ABS will function just the same. It appears you can swap your original hubs over to the new knuckles but I have not verified this yet. Also, it appears the Gen 2 hub's ABS connector is the same. Again, I have not verified this. Our cars stock ABS system sucks, period! IMHO is damn near useless and even when working 100%, it rarely works correctly to keep the wheels from locking up and helping you stop earlier. If you have driven newer GMs and even imports around the same age as our cars, you'll agree that our ABS system is inferior. So lets get started!! Lets start with the parts list! Parts from a 97-03 GP/Regal is your best bet to snag from at the yard. -Rear knuckles (nice and light aluminum!) -Rear hubs (Stock appears to swap over ok, but havent verified yet) -Rear caliper brackets -Rear cailper bracket bolts -Rear calipers -Rear caliper banjo bolts -Rear caliper pins -Rear rotors -Rear pads -Strut to knuckle bolts (You CANNOT reuse your orignal ones!) -Knuckle to lateral arm bolts, washers, nuts You will reuse these items! -Trailing arm bolts and nuts -Brake hoses -Brake hose to body brackets Other items you will need/recommended! -2 self tapping screws -Brake fluid Dot3/4 (Incase a Noob doesnt know) -Brake line (3/16") -Metric bubble flare fittings (if your old ones are too bad to reuse) -Brake parts cleaner -Someone to help you bleed the brakes Alright, now for some W-body moddin madness!! Step 1- Jack up vehicle, securely on jackstands Step 2- Remove the wheels, 19mm Step 3- Unbolt caliper bracket from knuckle, 18mm Step 4- Using small prybar, pry caliper and bracket as an assembly, off the rotor. Hang outta the way Step 5- Remove rotor. If stuck, hit with hammer on the front, a few good swings will knock it right off. Step 6- Remove trailing arm from knuckle. 24mm socket and 24mm wrench. If siezed, hammer outta the knuckle Step 7- Remove lateral link to knuckle bolts, 21mm Step 8- Remove strut to knuckle bolts, 22mm. Hammer out of knuckle Step 9- Now remove the ABS harness fromt the back of the hub if equipped and remove the knuckle assembly from the vehicle and take it out back and piss on it!!! Step 10- If not going through the hassle to get the Gen 2 rear e-brake to work, might as well remove it and save you a headache later in life when the shoes wear into the rotor or just rot away and make noise. Remove the hub, 10mm Step 11- Hammer the shoes down outta the way, and hammer the flange of the hub to remove it from the knuckle Step 12- Scrap corrosion from the knuckle where the hub fits Step 13- Cut backing plate like so, you need this is as a spacer to keep everything lined up. Step 14- Slide on cut backing plate and reinstall hub into knuckle. NOTE! 1 hub to knuckle bolt needs to be a short one from the stock Gen 1 knuckles, otherwise it will hit the lateral arm. The short ones need installed in the bottom front side Step 15- Mount knuckle onto car, start with strut to knuckle bolts. Use smaller Gen 2 bolts and nuts! 21mm or 22mm Edited April 27, 2010 by BXX Imp558 1 Quote
BXX Posted April 27, 2010 Author Report Posted April 27, 2010 (edited) Step 16- Mount lateral arms to knuckle using new long through bolt with washers and nut. 21mm Step 17- Mount trailing arm using the stock bolt and nut 24mm socket and 24mm wrench Step 18- Laugh at Ryanna!! Step 19- Cut corner from body. Makes for more room for brake hose to come out and not get damaged. Smooth out burrs Step 20- Slide on new rotor Step 21- Bolt up new caliper bracket. 14mm or 15mm. Install new hardware clips (can reuse original) and install new pads Step 22- Install caliper. IIRC the guide pins with the rubber bushing go to the bottor. 14mm or 15mm Step 23- Remove stock caliper from brake hose. Banjo bolt is normally 11mm. Can vary Step 24- Remove brake hose bracket to body. 10mm Step 25- Remove clip holding hose to bracket Step 26- Remove brake hose from hard line, vise grips with 16mm wrench will work Step 27- Hammer bracket off hose Step 28- Attach hose to bracket and caliper, find a good spot to mount the bracket and mount it using the self tapping screws. It may take some removing and installing of the hose to get everything in a good spot and not twisted to hell. You will have to tweak the original brake line around. It will fit good with no issues. -Passenger side mounting of brake hose bracket with line. Had to run new line to passenger. Driver side was mint. Step 29- Make sure everything is good and tight, and that the hoses are not kinked. Rob used Goodridge lines on his, I used stock lines on mine. Neither had any rear fitment issues. Step 30- Bleed brake system. Our system is split-diagonal so your best bet to bleed the system is to go in this order. RR-LF-RF-RR. Then do the pattern again and everything should be good to go. Step 31- Sit back and enjoy the fruits of your labor!!! And a few random pics. -Comparison of the stock Gen 1 and Gen 2 knuckles -Teh Flows Yo!!! (aka Flowmasters) -Gen 2 parking brake show and adjuster. If you want to keep these and get a working cable setup, take into account new shoes are over $50, so get a nice set at the junkyard! -Whole mess of parts ready to go on. -Robs ass crack!! -Rob takin pictures of my junk!! I have no clue what was happening here.. I plead the 5th, I already had a few beers in me! Enjoy!! Feel free to ask questions as well. -Bob Edited April 27, 2010 by BXX Quote
tornado_735 Posted April 27, 2010 Report Posted April 27, 2010 Awesome writeup! Even a tard like me can understand it! Quote
94GPGTP Posted April 27, 2010 Report Posted April 27, 2010 size of the rear sway bar? Which vehicle it came off of... Or is it a addco? Quote
jeremy Posted April 27, 2010 Report Posted April 27, 2010 very nice write up but you should really add a step to include cleaning/painting the old rusty caliper before reinstalling Quote
BXX Posted April 27, 2010 Author Report Posted April 27, 2010 size of the rear sway bar? Which vehicle it came off of... Or is it a addco? 7/8" (22mm) 95 LQ1 equipped MC/Lumina. Possibly 96 as well. Be careful as not all of those even got the larger 22mm bar. Quote
BXX Posted April 27, 2010 Author Report Posted April 27, 2010 very nice write up but you should really add a step to include cleaning/painting the old rusty caliper before reinstalling I made a comment about it to him, but between I think him forgetting and also could care less since the exterior needs some rust repair and body work. Quote
jman093 Posted April 27, 2010 Report Posted April 27, 2010 (edited) Awesome! I was going to do this myself, this makes it a whole lot easier. Couple of things. First, the parking brake. Some cars got a caliper with an integral parking brake. The Regal/GP you guys got obviously doesn't have it and my neiter my father's 01 Monte SS or my Mom's 06 Impy has it either, but I just today saw in the shop today a 3G GPGT with this integral style parking brake on the back of the caliper. It LOOKED just like the one on our calipers from the spring on the back to the way the cable attaches. Don't know for sure if it's the same without having each one available to compare next to each other, but I'm sure it could be made to work. I'm going to look into this. EDIT: I was just looking up parking brake descriptions in service information for a bunch of different 2nd/3rd gen W-bodies and the 3G GP got this style caliper and is the only W-body to get a retractable integral parking brake since gen 1/1.5's. All other 2/3's have the drum setup for parking brakes. Not sure why GM would do this. Second, what about all the different sizes on the rear brake packages? Obviously the GXP has larger brakes, but it is different setup. I want to to say the 00+ Impy/Monte had larger brakes on some or all of the cars, but I don't know for sure. Would be nice to get the biggest brakes possible. Edited April 27, 2010 by jman093 Quote
White93z34 Posted April 27, 2010 Report Posted April 27, 2010 excellent information! I think this will become a write up shortly! Quote
BXX Posted April 28, 2010 Author Report Posted April 28, 2010 04+ GPs are the only ones to get integral parking brake. Again, those calipers have more siezing issues. K.I.S.S. AFAIK, the Impy and MC could get larger front ones or just slightly different. As far as the rear is concerned I dont believe they got anything different. Ill have to look into it more. But if you want bigger brakes, then the 12" GXP setup is the way to go. Our cars need larger front brakes way before 12" rears. The 97-03 rear setup works great. If you wanna keep the parking brake, which works great, and if you have cable issues, almost any area has a place that can make custom cables for a very reasonable price. Just swapping over cables and the pedal assy from a 97-03 GP prolly wouldnt be too hard. I may actually look into that on my next run to pullapart. Quote
jman093 Posted April 28, 2010 Report Posted April 28, 2010 (edited) I've been doing more digging. Here's what I found out about rear brakes on W-bodies. All 94+ w-bodies (1G,2G,3G) rear rotors are 278mm(10.94") except the following: 3G GP's which have a 270MM (10.63") rotor GP GXP's have the 12" rear brakes. There's 2G GP's running these on stock wheels, so I think they would fit our 16" wheels as well. We'd probably have to find a larger spare tire though from a yard. The other factor into performance though is the brake pad size differences, if there are any since the surface area of the pads would also affect performance. I'm guessing the 3G rotors are only smaller due to the lack of the brake drum in them and they may actually have more pad surface area. Would be interesting to see the different pad sizes. I think I am going to try the 3G GP brakes when I get around to doing mine. Personally I haven't seen any siezing issues on 3G GP's. It's a way better caliper than even the 94+ ones. The other advantage is it's aluminum for even more unsprung weight savings than is provided with the knuckle swap and lack of a parking brake shoes. All other w-body rear calipers are the iron/steel except the PBR's on the GXP's, but even those paired to a heavy ass 12" rotor. Edited April 28, 2010 by jman093 Quote
Skunkworks_Zed Posted April 28, 2010 Report Posted April 28, 2010 (edited) I've been doing more digging. Here's what I found out about rear brakes on W-bodies. All 94+ w-bodies (1G,2G,3G) rear rotors are 278mm(10.94") except the following: 3G GP's which have a 270MM (10.63") rotor GP GXP's have the 12" rear brakes. There's 2G GP's running these on stock wheels, so I think they would fit our 16" wheels as well. We'd probably have to find a larger spare tire though from a yard. The other factor into performance though is the brake pad size differences, if there are any since the surface area of the pads would also affect performance. I'm guessing the 3G rotors are only smaller due to the lack of the brake drum in them and they may actually have more pad surface area. Would be interesting to see the different pad sizes. I think I am going to try the 3G GP brakes when I get around to doing mine. Personally I haven't seen any siezing issues on 3G GP's. It's a way better caliper than even the 94+ ones. The other advantage is it's aluminum for even more unsprung weight savings than is provided with the knuckle swap and lack of a parking brake shoes. All other w-body rear calipers are the iron/steel except the PBR's on the GXP's, but even those paired to a heavy ass 12" rotor. Diameter isn't everything The stock '97 rotors that I used were definitely thicker than the '93 and '94 ones that I had around. Also, while OEM cast aluminum calipers do save weight, they flex far too much for any other benefit. I would rather shave some weight off of the iron calipers/brackets, and save up for a good 2-piece aluminum caliper. Edit: '94+ spare tires will fit, '88-'93 is too small. And Bob; I did this swap almost 3 years ago, and I haven't had any ABS issues. I used '97 hubs, since my stock '93s had broken connectors. They will mount just fine though, so using some Gen1 non-ABS hubs would work. Edited April 28, 2010 by Skunkworks_Zed Quote
Venom Posted April 28, 2010 Report Posted April 28, 2010 (edited) Awesome writeup bro! I think you pretty much covered it all. This project went very quick even with us taking our time to document and take pics, smoke/pizza breaks and me drinking a whole 12 pack almost by myself LOL. It is definitely a nice upgrade from my stock brakes since the RR was constantly seized and the aluminum knuckles shave some weight as well. And Jeremy, the calipers will be painted shortly, I just wanted to get the swap done first without messing up any paint job, plus I need new pads since the ones I got from the donor vehicle were worn more then I remembered. Edited April 28, 2010 by Venom cant spell! Quote
GOT2B GM Posted April 28, 2010 Report Posted April 28, 2010 Nice write up, the only thing I don't like is the bent up brake lines. Quote
BXX Posted April 29, 2010 Author Report Posted April 29, 2010 What do you mean? The brake line is perfectly fine. Last time I checked the OE line had bends in it too! And Rob, you only drank 5 beers scooter... Quote
GP4U2NV Posted April 30, 2010 Report Posted April 30, 2010 Why did you not use the parking brake? Quote
BXX Posted April 30, 2010 Author Report Posted April 30, 2010 Cause I have a slushbox for a trans and I dont feel like messing with getting new parking brake shoes (knuckles I got had fuxored ones) and I would have to deal with getting a cable and lever setup to work.. But mainly because I dont need one. Quote
GOT2B GM Posted April 30, 2010 Report Posted April 30, 2010 I'm sure its bent fine, it just looks wonky, otherwise, nice work. Quote
BXX Posted May 1, 2010 Author Report Posted May 1, 2010 Looks arent a concern with brake lines on car thats actually driven, especially when you dont see them. You can shorten and flare the line.. but I wasnt in the mood to flare and do lines more that it turned out I had to. I had to run the RR line from the caliper to midway under the car (just past the OE union that always rots out) If I was doing brake lines that are seen under the hood, they would look super nice. Did some on a friends 70 MC that looks 'showcar' style. However like i said, this isnt a show car that will sit on mirrors at shows, so 'niceness' was the least of my worries Quote
gpchris Posted June 7, 2010 Report Posted June 7, 2010 I skimmed so i may have missed it but if you dont atleast keep the drums on there will you not have a parking brake? Quote
BXX Posted June 7, 2010 Author Report Posted June 7, 2010 Yeah, if your goin to want to get the parking brake to work, you will need to keep all the parking brake drum stuff in place. Quote
gpchris Posted July 11, 2010 Report Posted July 11, 2010 I have a question. You said the 2g lateral arms are longer by 1/2" so don't you have negative camber? Plus if your lowered so that will throw it off a little too. Is there any fix for this? Quote
BXX Posted July 11, 2010 Author Report Posted July 11, 2010 I have a question. You said the 2g lateral arms are longer by 1/2" so don't you have negative camber? Plus if your lowered so that will throw it off a little too. Is there any fix for this? Yeah, its called an alignment. Quote
gpchris Posted July 11, 2010 Report Posted July 11, 2010 The only camber than can be adjusted is at the bottom of the strut and idk if it will correct that much negative camber. I just don't want to be riding on the side of the tire is all. Quote
BXX Posted July 11, 2010 Author Report Posted July 11, 2010 The only camber than can be adjusted is at the bottom of the strut and idk if it will correct that much negative camber. I just don't want to be riding on the side of the tire is all. The slotted KYBs allow for appx +/- 3.25* There is plenty of movement. Quote
