tornado_735 Posted April 9, 2010 Report Posted April 9, 2010 Well, I disassembled my rear passenger caliper to grease up the slides. They need it. The problem is that out of curiosity, I stepped on the brake pedal (with the rear brake line disconnected) to see what the fluid looks like, and I got nothing. No fluid, not even a drop. I now know why I have non-working brakes in the rear. What would cause this?!? Why am I getting no brake pressure to the rear lines? Quote
tornado_735 Posted April 9, 2010 Author Report Posted April 9, 2010 Is my master cylinder dead? FUUUUUUUUUUUUU Quote
RobertISaar Posted April 9, 2010 Report Posted April 9, 2010 Is my master cylinder dead? FUUUUUUUUUUUUU possibly... or there's something stuck in your brakeline that won't allow fluid to pass through... but that would cause bulging/exploding brakelines.... how many times did you hit the brake pedal? Quote
tornado_735 Posted April 9, 2010 Author Report Posted April 9, 2010 possibly... or there's something stuck in your brakeline that won't allow fluid to pass through... but that would cause bulging/exploding brakelines.... how many times did you hit the brake pedal? Well I went back out, and tried it with the engine running. I am still getting no fluid whatsoever. I pumped the shit out of them, and nothing. No exploding lines either, at least that I could see. Quote
RobertISaar Posted April 9, 2010 Report Posted April 9, 2010 try the other side... i wonder if the proportioning valve is sending all the fluid to the front... you know what, check every corner. get that out of the way now and we might have a clearer picture of WTF is happening... Quote
tornado_735 Posted April 9, 2010 Author Report Posted April 9, 2010 It's the same as it was when I did the brakes last May. The driver side rear is getting no fluid either. The fronts have to be getting fluid just fine, because I am able to stop, and I have brake dust all over both of the front wheels. Where is the proportioning valve? Inside the master cylinder? Quote
tornado_735 Posted April 10, 2010 Author Report Posted April 10, 2010 Goddamn it. This is turning into a clusterfuck. Quote
Cutlass350 Posted April 10, 2010 Report Posted April 10, 2010 (edited) (with the rear brake line disconnected) That's a very important piece of info. Summary: You should get a pressure bleeder. You might or might not be able to bleed a rear line without one. With an open brake line, you are very likely not to get any brake fluid out. You'd likely get one shot of brake fluid. After that, it's very unlikely that you'd get any brake fluid out again. What happens is that after the first pump, air is then sucked into the brake line. So, after that, you always "pushing/pulling" air. Also, it can be very hard/impossible to do the initial bleed of a rear brake line with just the "one man/bleeder screw method". And, the vacuum bleeders, speedi bleeders, one man container solutions are ~70% snake oil. Yea, they work for some people. And, some people win millions in the lottery. So, why aren't you putting all of your paycheck towards buying lottery tickets? Well, for the same reason that professionals don't use those snake oil solutions. You may or may not be able to bleed the rear brake line now with the bleeder screw method, or one of the snake oil methods. There are many variables! In the past, I had an ~80% chance of being to to bleed a rear brake line without a pressure bleeder. So, it's not hopeless. But, no guarantees. BTW: The links are old in the following tech article. For information on Bleeding Brakes, see: http://www.veryuseful.com/mustang/tech/brakes/bleeding.html You can now get the speedibleed system at: http://www.speedibleed.com/ I've had and used my KD Pressure Bleeder Model# 2222 for ~7+ years now . Good Luck! Edited April 10, 2010 by Cutlass350 Quote
RobertISaar Posted April 10, 2010 Report Posted April 10, 2010 i bought a $15 vacuum pump from autozone that worked damn good until i broke the face of the vacuum guage and started losing the adapters... that was a damn good investment. Quote
BXX Posted April 11, 2010 Report Posted April 11, 2010 And for anyone wondering, there is no external prop valve on our cars. Its internal on the Master Cylinder. Quote
GOT2B GM Posted April 11, 2010 Report Posted April 11, 2010 Unless you car is PM3 equipped (89-91 with ABS) then you have a proportioning valve under the car mounted on the drivers side rear seat floorboard. Quote
BXX Posted April 11, 2010 Report Posted April 11, 2010 Unless you car is PM3 equipped (89-91 with ABS) then you have a proportioning valve under the car mounted on the drivers side rear seat floorboard. Got a pic??? Im yet to see one on any of my ABS Ws Quote
tornado_735 Posted April 11, 2010 Author Report Posted April 11, 2010 Well, I need to grease up the slides on the driver side rear caliper. Weird thing is that the parking brake works a whole lot better now. I think I am going to stick a new, non abs master cylinder on there. Then we'll see where I stand. Quote
White93z34 Posted April 11, 2010 Report Posted April 11, 2010 I believe Matt is saying that ONLY PMIII cars have a external prop valve for rear brakes. disconnect the brake hoses from the lines and see if you get anything out of them. if not I would suspect something in your mater is screwed up. Quote
BXX Posted April 11, 2010 Report Posted April 11, 2010 Ok, your right, I re-read it and just kinda mistook what he typed. Quote
tornado_735 Posted April 11, 2010 Author Report Posted April 11, 2010 I believe Matt is saying that ONLY PMIII cars have a external prop valve for rear brakes. disconnect the brake hoses from the lines and see if you get anything out of them. if not I would suspect something in your master is screwed up. Thanks for reminding me, I forgot to mention I was going to do that before replacing the master. Quote
tornado_735 Posted April 13, 2010 Author Report Posted April 13, 2010 do you have ABS? Yeah, but the ABS is not functional, nor do I want it to function. :laugh: Quote
White93z34 Posted April 13, 2010 Report Posted April 13, 2010 you could try bleeding the brakes at the ABS unit. if there is air in there it could cause your issue with rear brakes. Quote
tornado_735 Posted June 25, 2010 Author Report Posted June 25, 2010 Update! Well, I know I need new rear calipers. That's a fact. But, tonight I decided to pull the lines going to the rear brakes off at the ABS pump, and see if I could get any fluid out of the pump. I had my girlfriend step on the pedal with the line to the right rear off. She got the pedal almost all the way down before I got any fluid out of it. I replaced the line, and had her repeat with the left rear line disconnected. Not a drop. So it would appear that something inside either my master or the ABS pump is screwed. Quote
White93z34 Posted June 27, 2010 Report Posted June 27, 2010 well at least those are cheap enough at pull a part yards anymore. Quote
