GRANDFURY Posted September 26, 2003 Report Posted September 26, 2003 Ok i've replaced my fuel filter, put on new wires and plugs new air filter, fixed my vaccuum leak and everything was good for a few days and today I had the same problem just shut the car off and then it wouldn't start back up again Stupid thing only does it sometimes under different conditions, and some times it stalls in drive or reverse when i'm idleing. After it sits for about half hour to a hour it starts right up and drives fine. I've already checked the fuel pump but it seems fine. Oh yeah the car is a 89" grand prix 2.8L. Any ideas?? This is driving me crazy :? Quote
gmrulz4u Posted September 26, 2003 Report Posted September 26, 2003 Hey, I see you're in London, Ontario as well... I have a lot of various tools that I can use to help you diagnose your problems...I have an OBD Scanner, Fuel Pressure Gauge, Vacuum Gauges etc. and am pretty good at diagnositc work... Let me know if you want to get together one day! Quote
stlunatics2oo3 Posted September 26, 2003 Report Posted September 26, 2003 i would place money it is a ignition control module mine did that when i bought my car Quote
hazmatic Posted September 26, 2003 Report Posted September 26, 2003 my car was basically the same then i made the car relearn idle n all was fine Quote
Robby1870 Posted September 26, 2003 Report Posted September 26, 2003 It could be a number of things, but the ICM or coils is a good place to start. How did you check the fuel pump? Robby Quote
GRANDFURY Posted September 27, 2003 Author Report Posted September 27, 2003 well I didn't really check the fuel pump but I heard it turn on and I just did the fuel filter. I did an idle relearn but now it runs worse :? I just bought a crank sensor but I can't see where the old one is I think I know but can only feel it not see. Quote
Robby1870 Posted September 27, 2003 Report Posted September 27, 2003 The pump can still make a noise and be bad. Check the fuel pressure with key in the ON position but dont start it. You should get 41-47 psi Robby Quote
GRANDFURY Posted September 27, 2003 Author Report Posted September 27, 2003 I don't have a presure tester, (for the schrader vavle?) and the cheapest one I could find was 198.99 and I don't have that money Thanx though. Quote
GRANDFURY Posted September 27, 2003 Author Report Posted September 27, 2003 Could it be the O2 sensor? Quote
Robby1870 Posted September 27, 2003 Report Posted September 27, 2003 Could it be the O2 sensor? Yeah, those Fuel Pressure gauges can be $$$. I dont think its the O2. The ECM only uses the O2 input once its warmed up and in closed loop, otherwise it uses the MAP and other inputs. And when in closed loop it just uses the O2 to read a rich or lean condition. A have never heard of a bad O2 makin the car stall, usually its a really rich condition. However, you might as well go ahead and change it if you feel its necessary. Its easy, and a new one is only like $20 Robby Quote
