alec_b Posted April 9, 2010 Report Posted April 9, 2010 (edited) '91 regal limited full digital cluster (not base) and '91 regal gs full gauges. Just want to see what all it will take wiring wise to swap. I know I need the buttons below the radio for switching display modes. Thanks! *GOT PINOUTS* I've gotten it broken down like this, I need to know what to do about the extra wires... ideas? ANALOG C1 – Cluster Fuse 10A Run Hot (PNK/BLK) C2 – Left Turn Ind. In (LT BLU) C3 – Interior lights dimming (GRY) C6 – Seat Belt Ind. In (YEL) C7 – Fuel Gauge In 90F 0E (PPL) C8 – Right Turn Ind. In (DK BLU) C9 – Ground (BLK) C10 – High Beam Ind. In (LT GRN) C11 – Tach In (WHT) C16 – ABS warning in (GRY/WHT) D1 – Alternator In (check gauges) (BRN) D2 – SES Light (BRN/WHT) D4 – Coolant Level Sensor In (YEL/BLK) D5 – Coolant Temp Sensor In (DK GRN) D8 – Cruise Ind. In (WHT) D9 – Oil Pressure In (TAN) D10 – Indic. Fuse 10A (PNK/BLK) D11 – Ground (BLK) D14 – VSS In 4000 PPM (DK GRN) D16 – BRAKE warning in (TAN/WHT) DIGITAL B5 – Parity Signal In (WHT) B6 – C Signal In (GRY) B7 – B Signal In (YEL) B8 – A Signal In (BLK/WHT) C1 – INDIC Fuse 10A (PNK/BLK) C2 – Left Turn Ind. In (LT BLU) C3 – Right Turn Ind. In (DK BLU) C4 – BRAKE warning in (TAN/WHT) C5 – ABS warning in (GRY/WHT) C7 – High Beam Ind. In (LT GRN) C8 – Season Trip Sw. (LT GRN) C9 – Ana/Digi Sw. (DK BLU/WHT) C10 – Lights On Input (YEL/BLK) C13 – Serial Data (ORG) C14 – Ground (BLK) C15 – PRNDL Fuse 5A (WHT/BLK) C16 – CLUST Fuse 10A (PNK/BLK) D1 – Ground (BLK) D2 – Seat Belt Ind. In (YEL) D3 – Coolant Level (YEL/BLK) D4 – Alt. In (BRN) D5 – SES Light (BRN/WHT) D6 – Cruise Ind. In (WHT) D9 – E/M Switch (LT BLU) D10 – Interior Lights Dimming (BRN) D11 – Oil Press. In (TAN) D12 – Coolant Temp. In (DK GRN) D13 – Fuel Gauge In (PPL) D15 – VSS In 4000 PPM (DK GRN) D16 – ELEC Fuse 15A (ORG) PINS ANALOG <->DIGITAL C1 – C16 C2 – C2 C3 - ? C6 – D2 C7 – D13 C8 – C3 C9 – C14 C10 – C7 C11 - ? C16 – C5 D1 – D4 D2 – D5 D4 – D3 D5 – D12 D8 – D6 D9 – D11 D10 – C1 D11 – D1 D14 – D15 D16 – C4 ? – B5 ? – B6 ? – B7 ? – B8 ? – C8 ? – C9 ? – C10 ? – C13 ? – C15 ? – D9 ? – D10 ? – D16 *UPDATE* I picked up a cluster at the yard today. Got the cluster, lens/trim, and control switches for $30. Wired the cluster to 12v when I got home and it powers up and works great. I shouldn't have any trouble getting it wired. It is from a column shift car, so it has the PRNDL indicator on it, and I plan on swapping out the trans. range switch and wiring it up to work properly. I was curious as to if anyone was interested in a writeup? I could do one if someone wanted, otherwise I'll just take before and after pictures. I know the 1st gen regals don't have much of a following, but I wanted to offer. Edited April 23, 2010 by alec_b Quote
alec_b Posted April 9, 2010 Author Report Posted April 9, 2010 Well I've done some more looking: It appears as though the trans. range switch is different between the analog and digital clusters, the digital one has more outputs for the A, B, and B and parity inputs of the cluster. However, since I'm going to use a GS cluster w/o PRNDL indicator I don't think those are required. The E/M button pod is wired up already, so that I can use. Serial data can be tapped at the DLC. Lights inputs can be tapped at the switch. There's a couple more fuse inputs on the digi cluster I'll have to add. If anyone has any other ideas let me know. I did find the post about swapping in a regal UB3, but it didn't really give me anything new. Quote
White93z34 Posted April 9, 2010 Report Posted April 9, 2010 I did it one a 88' Limited with a base digital cluster, do you have the analog one? I kinda just went by feel the whole way using a cutlass UB3 pinout as a rough guide. Quote
alec_b Posted April 9, 2010 Author Report Posted April 9, 2010 Yea I have the full analog cluster with all gauges, so I have all the required inputs already for UB3 cluster, as far as I can see, other than the trans. range inputs. But like I said I think I can do without those. Quote
alec_b Posted April 23, 2010 Author Report Posted April 23, 2010 TTT with an updated first post. Quote
