88red4cyl Posted April 9, 2010 Report Posted April 9, 2010 Got the oil changed on my Monte this morning, and as usual, reset the oil life monitor... Since then, the outside temp will only read 39° (the temp it was when it got reset)... It was close to 60 outside, and the DIC still read 39... Where is the sensor that the car uses for the outside temp? I restarted the car several times throughout the day, and it read 39 each time... Not really sure if its a DIC problem or a sensor problem... Thanks in advance! Quote
tornado_735 Posted April 9, 2010 Report Posted April 9, 2010 What if you disconnect the battery? I know it's a pain in the ass resetting all the settings in your radio/clock, but it might work. Quote
88red4cyl Posted April 10, 2010 Author Report Posted April 10, 2010 Ended up not having to unhook the battery... Just reset the oil life monitor a few times, and it started working again... Not sure how or why it did that, but thankfully its working now... Quote
