cutty Posted April 3, 2010 Report Posted April 3, 2010 A 1995 what?? If it is a cutlass sedan then either bulb number 577, or 891. Quote
swift13 Posted April 4, 2010 Report Posted April 4, 2010 well its in the vert section so i assume a vert the bulb is different it doesnt just get plugged in but i still have not found any anywhere except in the jukyard Quote
capcrunk Posted April 4, 2010 Author Report Posted April 4, 2010 i think its 891 i found 2 in auto zone im gonna try them out tommarrow if that doesn't work is there a fuse ? ? Quote
BN Posted April 17, 2010 Report Posted April 17, 2010 I just replaced one of each of these in my 93. I assume they're the same as yours? I took both burned out bulbs to Meijers and got them there. Quote
George Posted April 17, 2010 Report Posted April 17, 2010 (edited) My manual for 1994 says 885. I pulled a fog light out to verify - 885. I was looking for silverstar bulbs but they don't seem to make them. Street scene makes an hid style I think. Other numbers will fit but are only 27 watt or 35 watt and 885 are 50 watt and are brighter. My manual does not say what bulb is used for the third brake light for the vert so I will go out later and pull one out and get the number and check back. --- Ok, so I pulled the third brake light out, it had a strange 5 digit no. so I called advance autoparts and came up with the 891 no. Foglight bulb = 885 50 watt (takes 1 per side) Vert third brake light bulb = 891 10 watt (takes 3) Edited April 17, 2010 by George update Quote
Fmr12B Posted April 19, 2010 Report Posted April 19, 2010 Vert third brake light bulb = 891 10 watt (takes 3) The 891's are around $10 a bulb. I replaced only the middle bulb in the 3rd brake light. Quote
White93z34 Posted April 22, 2010 Report Posted April 22, 2010 if the 891s can be had at your local hardware store for far cheaper then a auto parts store. 12v 10watt halogen lamp Quote
