Crazy K Posted April 5, 2010 Report Posted April 5, 2010 lesson to be learned: ALL OBD 1.5 W platform cars have an OBD 1 type connector, but with NO ground. this includes: 94-95 CS 94-95 GP 94-95 Regal 94 3.4 equipped luminas only (94 3.1 equipped luminas are still obd 1) 95 luminas and MC You should always try to get your car scanned for issues to see what comes up. END OF STORY. Just because it still runs redneck strong doesn't mean an issue shouldn't be solved. Quote
RobertISaar Posted April 5, 2010 Report Posted April 5, 2010 lesson to be learned: ALL OBD 1.5 W platform cars have an OBD 1 type connector, but with NO ground. this includes: 94-95 CS 94-95 GP 94-95 Regal 94 3.4 equipped luminas only (94 3.1 equipped luminas are still obd 1) 95 luminas and MC You should always try to get your car scanned for issues to see what comes up. END OF STORY. Just because it still runs redneck strong doesn't mean an issue shouldn't be solved. huh? a ground is required for a scanner to communicate... Pin M is usually Data and Pin A is ground. the MC has these. and the 93 3100 cuttys belong in the OBD1.5 section as well since it has just a slightly more primative version of the 94-95 3100 PCM. Quote
Crazy K Posted April 5, 2010 Report Posted April 5, 2010 trying again: ALL OBD 1.5 W platform cars have an OBD 1 type connector, but with NO set up for a paperclip or "key" tester. this includes: 93 3100sfi equipped CS all 94-95 CS all 94-95 GP all 94-95 Regal 94 3.4 equipped luminas only (94 3.1 equipped luminas are still obd 1) all 95 luminas and MC These vehicles are not compatible with the paperclip test method as they are not intended to be scanned that way. They must be scanned with a compatible scan tool only. As such the configuration of wires in the socket do not match the traditional OBD 1 paperclip testable set up. Quote
WhatTheFehl Posted April 5, 2010 Report Posted April 5, 2010 Another lesson to be learned here: If you have a car with OBD 1.5 and cannot scan it yourself, have it scanned at PepBoys for free, rather than paying a dealership out the wazoo for it. Quote
Hairdo12 Posted April 5, 2010 Report Posted April 5, 2010 Well my Check engine light is still on even after what I did. My car is running better than it ever has and I don't think I am going to worry about it. Does odb1.5 check vapor pressure in the gas tank? Check your cap and make sure its tight. Quote
AL Posted April 6, 2010 Report Posted April 6, 2010 The check engine light doesnt mean pop your hood and see if the engines still there, it means something is wrong, fix it! Quote
