2002 GP GT Posted March 31, 2010 Report Posted March 31, 2010 Anyone have a fix for this? It just started a few weeks ago, it fills up quick just sitting. I poured some water through the heater intake at base of windshield, it doesnt seem to be the source. Thanks Quote
terryk2003 Posted March 31, 2010 Report Posted March 31, 2010 It's a very common problem! Mine is doing it too and I need to fix it asap. Under the plastic trim in the cowl area there is a piece of weatherstripping the most likely needs reglued...there is a write up somewhere that I will try to find and post the link up here. Quote
terryk2003 Posted March 31, 2010 Report Posted March 31, 2010 http://www.grandprixforums.net/water_floorboard.php try that! Quote
Euro Posted March 31, 2010 Report Posted March 31, 2010 I can't remember which years had which...but you may be lucky and have a 2 piece cowl. That'll make this so much easier!! However, I think the early 2nd Gen's had the 2 piece. Trying to work around the cowl as it's bent up a bit of a pain, but it shouldn't be too bad! Quote
2002 GP GT Posted April 2, 2010 Author Report Posted April 2, 2010 Mine was 2 pc, just got through with the fix (just in time for more rain) Didnt need to remove the pass wiper arm, just ran the wiper till it was at 90 deg up, then shut off ignition so it stayed out of the way of the fastener. Thanks again. Quote
pitzel Posted April 2, 2010 Report Posted April 2, 2010 You sure its rainwater? Air conditioners have a habit of doing that, and we're back into air conditioning season in many parts of the country. Quote
terryk2003 Posted April 3, 2010 Report Posted April 3, 2010 Awsome! Glad it worked out! Thanks for the tip of putting them up! That's what I'll probably do when I do mine! Pretty sure I have the two piece cowl too. Quote
sl3196 Posted April 3, 2010 Report Posted April 3, 2010 I have the one piece cowl but it wasn't too bad to fix. Quote
Biohazed Posted April 5, 2010 Report Posted April 5, 2010 I have the same problem with the '00 and there is a better permanent fix you may be interested in: http://www.grandprixforums.net/f73/water-floorboard-take-2-permanent-fix-6961.html Quote
Euro Posted April 5, 2010 Report Posted April 5, 2010 Not bad, maybe if mine starts to leak again I'll rip that shit out Quote
Biohazed Posted April 5, 2010 Report Posted April 5, 2010 well I just got my peice today and it ended up being $3.56 so couldn't say no to that lol Quote
Stevo Posted April 11, 2010 Report Posted April 11, 2010 Use the search function. I even did a write up for it that for some reason no one stickied. http://www.w-body.com/showthread.php/41249-I-am-seriously-at-my-witts-end....%28cabin-filter-Water-Leak%29?p=783011 Quote
terryk2003 Posted April 12, 2010 Report Posted April 12, 2010 well I just got my peice today and it ended up being $3.56 so couldn't say no to that lol did you get it from a dealer?.. Quote
Regal_GS_1989 Posted April 12, 2010 Report Posted April 12, 2010 Use the search function. I even did a write up for it that for some reason no one stickied. http://www.w-body.com/showthread.php/41249-I-am-seriously-at-my-witts-end....%28cabin-filter-Water-Leak%29?p=783011 Thanks! I was just about to post that up here. Quote
Addicted to eaton Posted April 13, 2010 Report Posted April 13, 2010 Im scared to see what happens when it rains and my 1999 is ourside... :S Quote
