Injector Replacement
It's time to replace the injectors in my 96 GP. It's 3400 swapped but still using the 3100 fuel rail and injectors.
I'm looking at going with the Bosch Design III injectors p/n F6VE-A5A. These are listed as a replacement for the c302 Ford Yellow Top injectors, which I believe is a common replacement for the 3.1/3100 crowd.
Can anyone confirm that these Bosch injectors are plug and play into the 3100 fuel rail?
I have a set of 96 3.4 injectors
but yes, the "19" lb ford injectors work for people who have installed them in TGPs, assuming this is the same injector you speak of. for example, what a 95 ford modular motor in a crown vic should have.
