CutSupreme93 Posted March 24, 2010 Report Posted March 24, 2010 Leaking fuel from one of the two lines that come up under the intake plenum, its leaking from the connector closest to the front of the car i have no idea what to call the parts, not sure if i just need a o-ring or something or what i tried looking on autozone and couldnt figure out what part i need, also the line that is leaking moves a good amount and the other line doesnt move at all, anyone know what part to call it and or where i can buy it? thanks! Quote
Crazy K Posted March 24, 2010 Report Posted March 24, 2010 year?engine? Pic? is it UNDER the intake, or the rubber feed line from the metal fuel line on the body(below the brake master cylinder) to the fuel rail, or between the quick connect and the fuel rail... need to know. Quote
Crazy K Posted March 24, 2010 Report Posted March 24, 2010 ok You need a fuel rail disconnect tool http://www.autozone.com/autozone/catalog/accessories/accProductDetails.jsp?counter=4&categoryDisplayName=Tools&fromString=search&itemIdentifier=246367_0_0_&productId=246367&sortType=&parentId=6-10&filterByKeyWord=fuel+rail+disconnect&categoryNValue=100006&navValue=101529&fromWhere=&itemId=1529-10&displayName=Fuel+line+disconnect+tool+for+GM%2C+Ford+and+Chrysler&store=624&skuDisplayName=Fuel+line+disconnect+tool+for+GM%2C+Ford+and+Chrysler&brandName=OEM On a 1993 LQ1 the line is double ended removable, meaning at has a quick connect at both ends. Are you able to go to a j/y and pull one from a donor? it needs to be identical... etc etc etc. earlier years (91-) will be threaded at both ends, and 94 will only have an engine side quick connect. meaning a used part must be 93, but might be 92 as well. I actually have one of these lines here... Quote
douellette Posted March 25, 2010 Report Posted March 25, 2010 are you sure its snapped on all the way? in the pic it doesnt look like its snapped on as far as the other line. Quote
CutSupreme93 Posted March 25, 2010 Author Report Posted March 25, 2010 ok thanks for the help! i tried pushing it in all the way but it wont snap in and is still leaking, its not a huge leak Quote
