Jonpro03 Posted March 27, 2010 Report Posted March 27, 2010 If you need some help, I can come up there on Sunday. Quote
RobertISaar Posted March 27, 2010 Report Posted March 27, 2010 limp mode: 1 fan should kick on when you roll the key forward and you will NOT be able to connect to the datastream. Quote
94GPGTP Posted March 27, 2010 Author Report Posted March 27, 2010 Yes sir. I'm in limp mode. How safe is it to drive in limp mode?? I'm 30 miles from home and I had to drive it 5 miles in limp mode to get where I'm at. Quote
RobertISaar Posted March 27, 2010 Report Posted March 27, 2010 Yes sir. I'm in limp mode. How safe is it to drive in limp mode?? I'm 30 miles from home and I had to drive it 5 miles in limp mode to get where I'm at. safe? should be fairly safe assuming you're using the stock MEMCAL, or you keep it the hell away from boost with a regular 3.1 MEMCAL. limp mode dumps a LOT of fuel and has very little advance. no TCC lockup either. Quote
94GPGTP Posted March 27, 2010 Author Report Posted March 27, 2010 Yes stock memcal. Just modified for 5speed and 14 psi. Quote
RobertISaar Posted March 27, 2010 Report Posted March 27, 2010 ??? hardware mods for a 5 speed and more boost? or are you talking about the tune? either way, keep it out of boost and you'll be fine. Quote
94GPGTP Posted March 27, 2010 Author Report Posted March 27, 2010 The tune on the chip is tuned for 5 speed and more boost Quote
94GPGTP Posted March 28, 2010 Author Report Posted March 28, 2010 Swapped the chip back to my reiable one and back to normal for now.. I added seafoam to the tranny oil to help loosen things up.. It is soo hard to shift gears its not funny.. I also added 3 Gallons of 110 Octane Race fuel to a full tank of 93 Octane today.. Man i love the smell of race fuel.. Heres a video of LIMP MODE.. Quote
RobertISaar Posted March 28, 2010 Report Posted March 28, 2010 yeah, that's limp mode alright... Quote
94GPGTP Posted March 31, 2010 Author Report Posted March 31, 2010 Frickkin turbo oil seal blew.. now burning oil.. Quote
94GPGTP Posted April 1, 2010 Author Report Posted April 1, 2010 Well.... My FFP coilovers are rebuilt.. I reused the upper mounts and coils.. I got new Sleeves and adjuster nuts and struts.. My New Trailing arms came in today as well.. Love Them!! BEEFY! I guess im going to get gen 2 lateral links as well.. So i have progress pics on swapping everything over.. 1. Start with old FFP Coilovers 2. Get New Struts, Sleeves, Adjuster Nuts 3. Sleeve Doesn't Fit Strut 4. Grind The Welded In Nut And Little Of The Weld For Clearance For The Sleeve (I guess i bought the wrong sleeves and had to get them bored out.. This is what they look like after bore job.) Quote
94GPGTP Posted April 1, 2010 Author Report Posted April 1, 2010 5. Add Coil Spring 6. Add Taperd Washer 7. Add Poly Isolator 8. Install Upper Mount 9. Install Poly Isolator 10. Install Washer Quote
94GPGTP Posted April 1, 2010 Author Report Posted April 1, 2010 11. Install Lock Washer and Lock Nut 12. Tighten Nut and You Have A Complete Coilover Heres my Gen 2 Trailing arms.. Quote
94GPGTP Posted April 7, 2010 Author Report Posted April 7, 2010 Saturday night i got bored and started buffing the TGP.. I started on the DS fender and Hood.. got both done that night and took about 1.5-2.0 hours.. Sunday after church i immediatly went outside and finished the car.. 5.5-6.0 hours later i ended up with this.. I took the pics in town at a friends house for better scenery.. I hit 129,000 too.. In the middle of the pics it started to rain.. FTMFL after the detail.. Dont mind my "tips" temp extensions for now until i get a 3" system under there.. Quote
94GPGTP Posted April 7, 2010 Author Report Posted April 7, 2010 Got my Gen 2 lateral links today at the Junkyard.. Also when i came home my Poly inserts for the Gen 2 lateral links were at the door.. So i have everything to finally lower the rear of the car.. Im going to burn the bushings out of the lateral links and paint them red either PC or RC.. Ill push the bushings in and get the car ready for dismantling.. Me and steve are going to replace his front suspension this friday/saturday and after that the TGP will get the rear lowered.. I also need to put my SS brakelines on the rear.. Ill get some pics up of the gen 2 laterals and Poly bushings.. I picked up 2 doors from a Black 90 TGP, Front Bumper from the same car and the Louvers.. Got them last night.. Im replacing my doors since the ones on there are JUNK.. they have been repainted and looks crappy and the body panel bracket is gone so my panel flaps around.. Ill be changing the front bumper and doors in the near month.. Quote
White93z34 Posted April 7, 2010 Report Posted April 7, 2010 looks great! Wish my paint was 1/2 as nice! Quote
Twenty Posted April 7, 2010 Report Posted April 7, 2010 Very nice! I love that gauge cluster, so much nicer with a tachometer. Quote
94GPGTP Posted April 7, 2010 Author Report Posted April 7, 2010 looks great! Wish my paint was 1/2 as nice! Oh it is.. the grime is actually saving the paint.. My car looked like yours when i got it until i hand washed it and it looked ehhh ok and then i buffed it with 3M cutting compund, then a glaze compund and then wax and she looks like this.. :laugh: Quote
GOT2B GM Posted April 7, 2010 Report Posted April 7, 2010 looking great, I cant wait for my buffer to come so I can clean mine up. Quote
swift13 Posted April 7, 2010 Report Posted April 7, 2010 that looks good man! now while your changing my suspension i will be buffing the gtp i assume :laugh: Quote
IRONDOG442 Posted April 7, 2010 Report Posted April 7, 2010 Looks like its a baby pampers time !! Quote
94GPGTP Posted April 13, 2010 Author Report Posted April 13, 2010 Well its time to attack the rear suspension.. I got the Gen 2 laterals sandblasted and PC'd.. I also installed the ES Poly bushings.. I just started today tearing out all the old rusty crap.. I got the leaf out.. Rear lateral.. And upon getting the nut off the forward lateral i discovered the gas tank need to be dropped.. So i called it quits for today until tomorrow.. Everything has came apart fairly easy.. I have pics of the laterals and trailing arms.. Ill snap some pics of the suspension tomorrow.. Quote
GOT2B GM Posted April 14, 2010 Report Posted April 14, 2010 those are stock gen 2 arms PC'd? looks great! Quote
Twenty Posted April 14, 2010 Report Posted April 14, 2010 Too nice to put under the car. :laugh: Those look amazing, almost like aftermarket units with that finish. Quote
RobertISaar Posted April 14, 2010 Report Posted April 14, 2010 those are VERY nice... all of my suspension components match as well, but i don't think rust is a desired color. Quote
