94GPGTP Posted March 20, 2010 Report Posted March 20, 2010 Ok so i tearing the TGP down this weekend to fix a few things and do major Upgrades.. I am replacing the extremely leaky X-Over, Replacing the 282, 96 Knuckles, 2" lowering Springs, KYB struts, 34mm Sway Bar, ES Poly sway bar bushings, ES Poly Lower Control arm bushings.. The Rear gets coilovers and new trailing arms with Poly bushings. (future upgrades in the rear is 2nd Gen laterial links to freshen up and stiffen it all up).. But enough rambling.. I want to Wrap my DP and X-Over and shift cables with this heat wrap that i bought its 1/16" x 2".. How many layers do i need to do and how much of an overlap? Quote
RobertISaar Posted March 20, 2010 Report Posted March 20, 2010 good idea to use it on the crossover(since it will keep the heat in the exhaust stream, meaning less underhood and a bit faster turbo spool), much less useful on the downpipe(since the exhaust lost a significant amount of heat to the turbo itself)... i would wrap it so that there is a solid two layers over the entire crossover. shift cables could probably stand less. and i guess if there is any left, go nuts on the downpipe. Quote
94GPGTP Posted March 20, 2010 Author Report Posted March 20, 2010 good idea to use it on the crossover(since it will keep the heat in the exhaust stream, meaning less underhood and a bit faster turbo spool), much less useful on the downpipe(since the exhaust lost a significant amount of heat to the turbo itself)... i would wrap it so that there is a solid two layers over the entire crossover. shift cables could probably stand less. and i guess if there is any left, go nuts on the downpipe. I have 100'.. I just wanted to cover everything up to keep heat away from parts that can melt..( wires, Shift cables) The shift cables are at least the most 3/4" away from the DP.. Thats why i wanted to wrap the DP and Cables to keep them from fighting each other and possibly ruin the cables.. So what you think.. Start wrapping it and cover half of the previous wrap until i get 2 layers on the x-over.. One layer should be suffice on the DP and cables.. ( basically making a sleeve for the cables) Quote
RobertISaar Posted March 20, 2010 Report Posted March 20, 2010 So what you think.. Start wrapping it and cover half of the previous wrap until i get 2 layers on the x-over.. One layer should be suffice on the DP and cables.. ( basically making a sleeve for the cables) more or less... but since you have 100' of it, you have plenty to spare for the shift cables and and downpipe. if the cable really does run that close, i would give it more attention. Quote
94GPGTP Posted March 20, 2010 Author Report Posted March 20, 2010 So what you think.. Start wrapping it and cover half of the previous wrap until i get 2 layers on the x-over.. One layer should be suffice on the DP and cables.. ( basically making a sleeve for the cables) more or less... but since you have 100' of it, you have plenty to spare for the shift cables and and downpipe. if the cable really does run that close, i would give it more attention. thanks Quote
94GPGTP Posted March 21, 2010 Author Report Posted March 21, 2010 Ok so Im tired today of working on the TGP.. I did it all myself and swapping that tranny out was a PITA to get in! So i got the tranny swapped and the 34mm Sway bar in.. I heat wrapped the new X-over, DP, and shift cables like i planned on to.. I didnt even use a whole roll which is 50ft.. So tomorrow what i have left to do is press in the poly bushings into my newer control arm since i bent the last spare set i had, install the control arms, install ES sway bar bushing, disassemble the 96 knuckles to put lowering springs in and KYB struts for both sides, Install struts, put in CV's and brakes and set her on the ground.. Then all that is left is to bolt the x-over down, the DP, the turbo and install the charge pipes.. I also made one improvement while the tranny was out.. when i did the swap and finished it the tunk release didnt work.. so i connected the wires at the tranny switch plug to have it work all the time.. its going to be nice to be able to use the trunk release again.. Alot of work has been done and still some left.. Cant wait for this stage of work to be finished.. Old 282 New 282 Spec Stage 3 clutch and shot with the tranny out My new X-over (I Rebuilt It) New X-Over Wrapped and Set in place DP Wrapped New and Old Parts Quote
mfewtrail Posted March 21, 2010 Report Posted March 21, 2010 I'm curious why you chose that style flex for the crossover instead of the typical braided w/ inner liner flex everyone else usually goes with... Quote
94GPGTP Posted March 21, 2010 Author Report Posted March 21, 2010 Personally i havent been able to find the braided flex joints that are short and have small openings.. I have found ones that were a total of 4" long and 2 1/4" opening and its all wayyyy to big and would be boogered up.. These look just like the factory and have more flex than the factory and the inlet/outlet were maybe 1/16" larger.. One end was 1 3/4" and the other end 2" just like the x-over piping is.. Quote
94GPGTP Posted March 22, 2010 Author Report Posted March 22, 2010 Put the 96 Knuckles together today.. i have to reset the springs in the lower mount since i didnt get them right on.. its a PITA right now.. I also just ordered stainless steel brake lines.. 88.00 shipped Quote
94GPGTP Posted March 23, 2010 Author Report Posted March 23, 2010 Stainless braided brake lines came today.. I was shocked.. one day delivery.. I got the poly bushings into the control arms after destroying 3 control arms.. Keep that on the DL.. So now just assemble the suspension and finish bolting the turbo and im ready to rock and roll again.. Cant wait!.. Heres a couple pics of the control arms.. Quote
xtremerevolution Posted March 24, 2010 Report Posted March 24, 2010 SCORE! Let me know how she handles. Quote
xtremerevolution Posted March 24, 2010 Report Posted March 24, 2010 When are you planning to be done with this? I'd love to come by and see that thing. Quote
94GPGTP Posted March 24, 2010 Author Report Posted March 24, 2010 Well im beat.. I got everything in the front suspension done so far that i know of.. Its all bolted down and greased up.. Sway Bar bolted down, Lower Control arm are tight, Ball joints in, tie rods in, and CV's are in.. I ended up changing out my brake system when i did the SS Lines.. I used a well known good set of calipers, mounting brackets, Pads (newer),Rotors (Newer) from the 96 Lumina LS 3.4 i parted awhile back.. I just need to put the SS Lines on the rear brakes and bleed the system out.. Then to the easy part.. i just have to bolt the turbo back on and all the piping and should be good to go again.. Oh and another thing.. the rear coilovers are not ready yet because the sleeves had to get machined out to fit over the strut housing and the machine shop isnt going to get to it until they get a job in.. That way its free for me.. So im gunna sit funny for a bit until next week when i get my coilovers on.. Quote
94GPGTP Posted March 24, 2010 Author Report Posted March 24, 2010 When are you planning to be done with this? I'd love to come by and see that thing. Well if i bust my balls tomorrow i could have it running but not driving by later in the evening.. I need to bleed the brakes.. So if I dont get her finished up tomorrow it will be Friday for sure.. Quote
94GPGTP Posted March 26, 2010 Author Report Posted March 26, 2010 Well didnt get as far as i wanted to but it will make tomorrow really short and i should be able to drive her.. I had to tap out the holes for the DP and then had to go get SS bolts for the DP to turbo.. So that shot 1 hour to 1 hour 30mins down the drain.. But I got the shifter cables bolted down, X-over is tightened down, turbo bolted down, and DP to turbo is bolted down.. I have to tighten the bolts that hold the DP to the DP holding bracket and connect the exhaust to the DP.. That pretty much takes car of the hard part.. Then i just need to put the IC piping on and the STB.. I also have to custom fit my oil catch canister to the engine bay too.. Im still spewing oil outta the breather.. Passenger Side Drivers Side Underside Shot of tranny and wrapped DP and Cables Leaky X-over Bent control arms Shots of the X-over,Turbo,DP Quote
94GPGTP Posted March 26, 2010 Author Report Posted March 26, 2010 Oh and i bought these to go with the coilovers.. Should have the rear done next week.. But driving it in the meantime.. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360189766964&viewitem=&sspagename=STRK%3AMEWAX%3AIT Quote
Jonpro03 Posted March 26, 2010 Report Posted March 26, 2010 nice work X2... cant wait to see it Quote
swift13 Posted March 26, 2010 Report Posted March 26, 2010 why didnt you tell me about this i had to find out by searching. man i thought we were cool? it looks good cant wait to rip it down the street Quote
94GPGTP Posted March 26, 2010 Author Report Posted March 26, 2010 Got any more pics of the cables??? what do u need to know? Which cable is shift and select? I'll check Quote
94GPGTP Posted March 27, 2010 Author Report Posted March 27, 2010 Big problems.. the tranny is hard as hell to shift and the new chip from adam took a crap again.. this is the 2nd time this chip happened.. maybe my computer is no good? also how can you tell if the car is in limp mode? Quote
