Speedometer glitch??
Ok, was on my way to work and noticed that my speedo needle was sitting at 45 when I knew I was going faster. Hit the gas and it shot to where it needed after a second.
What's up? Speed sensor maybe?
considering the age of the car, it could be the guage cluster itself... a sensor like that shouldn't "stall" on a number. the wiring could also be bad, but i would put my non-existant money on the cluster first.
cluster is sticking. sometimes a slightly bent needle can do it but usually the stepper motor starts to fail and stick
Can motor be replaced?
Not usually as most are soldered directly to the board but soe have press in pins
Sounds like a plan for this car. Seems like I never should have got it :frown: But, I like it :biggrin:
