what size speaker for front and rear in a 95 ???
i see it has tweeter location and a speaker location up front ? thanks in advance
i believe its 6 1/2 but it may be 61/4
most stores that sell speakers can look it up easy
  • 2 weeks later...
In the 95 convertible the fronts are 5 1/4 with a tweeter and the rears are also 5 1/4.
  • 3 weeks later...
I got bit I bought some Boston Acoustics’ 6 1/2's for the rear because my local stereo shop said so, then I took the panel off to find out they were 5 1/4's. The covers need to come off to get the speaker out so be careful because the nut likes to break off. If the plastic breaks off it has a small hole where you can add a small screw and washer to keep the grill on. To get the speaker out I broke off the rivit on the back side of the speaker so I didn't tear the quarter trip panel and then used a screw and nut to mount the speakers.
Also make sure that you don't buy a speaker that sticks out to far, I had to mount the Boston's on the inside of the panel instead of the outside to get the grill on. I imagine the same is for the door speakers but I have not gotten that far yet.
REMOVE THE DOOR PANEL TO ACCESS FRONT SPEAKERS. they are not mounted to the door panel.
