supertrick_05 Posted March 15, 2010 Report Posted March 15, 2010 I popped the dash pad up today to hide a wire underneath it and ever since then, my HUD hasn't worked. Was I supposed to remove the HID pod off of the dash before I popped up the dash pad? Did I most likely unplug something when I lifted it up? Quote
digitaloutsider Posted March 15, 2010 Report Posted March 15, 2010 Are you sure the HUD isn't on at all? Look down into the HUD from the outside just to make sure. I don't know how the revised GP HUDs work, but on my Cutlass, pulling the dash involves removing the HUD unit itself, and there's a little spring-loaded tab on the bottom that sits in a metal tray and the HUD adjuster moves it. If it pops out of there, it goes way out of whack. Quote
GTP091 Posted March 15, 2010 Report Posted March 15, 2010 On my 91 the HUD is removed by taking out 2 - 7mm screws that bolt to the HUD from under the dash in the instrument cluster bezel. There is a metal bracket with 4 of the same screws that are bolted to the dash structure. Im not sure how you could have gotten the dash pad completely off without taking the hud off first. Possibly you ripped the threads out?? There is a harness that attaches to the HUD, you likely disconnected it. Also check the light sensor in the drivers dash speaker is disconnected. Quote
supertrick_05 Posted March 15, 2010 Author Report Posted March 15, 2010 No, I didn't take the dash pad completely off...I just popped it up a little to run a wire underneath. I'll check it out tonight. Quote
GTP091 Posted March 15, 2010 Report Posted March 15, 2010 I just checked my spare HUD and ya it looks like you could have easily popped the harness out; hopefully thats the prob Quote
Jonpro03 Posted March 15, 2010 Report Posted March 15, 2010 and there's a little spring-loaded tab on the bottom that sits in a metal tray and the HUD adjuster moves it. If it pops out of there, it goes way out of whack. X2 grr Quote
supertrick_05 Posted March 16, 2010 Author Report Posted March 16, 2010 Yeah, I think that's what happened because this morning I saw a faint green glow on the windshield where the HUD comes up, but did not display anything. I moved it up and down and it didn't show anything. So how do I fix this? Quote
