um, what is this mystery plug???
i was pokin around under the hood on the new monte and i found this connector not connector to anything. anybody know what it is?? or if its important??
for a 97 cutty 3100, i'm only seeing two connectors that look even remotely like that.
(C102) is mostly related to the fuel injectors, but also has the ground, reference and signal wire for the MAP
(C104) includes EVAP, EVO, and camshaft sensor....
if it's running correctly, i would assume that's an optional connector that is only used on cars that have Magnasteer(EVO) or whatever it's called...
The magnasteer plug is a 2 wire connector
well, whatever it is, it seems to be a plug for redundancy/cost savings.
i hope so, cause it is running fine and the check engine light isnt on.
i looked it up on rockauto and i found a plug that looks just like it under "fuel injector connector" and the description says: ACDELCO Part # PT588 {10-WAY FEMALE BLACK #12125676}
CONNECTOR,INLINE-TO F/INJR HARN
X2 on the cruise module...notice the throttle cable bracket in the background? It's missing a cable. :razz:
Cruise module.
Yup, without a doubt for the cruise module.
Looks like it was removed. Looking at the terminals I can tell why :lol:
Cruise module.
oooooh, yeah i noticed it was missing a cable and i was worried cause i thought it was the TV cable for the tranny haha
i havnt bothered to check to see if theres cruise control on the multifunction switch yet haha
Cruise was standard equipment.
Ive seen 94 and 95 3100 CSs without it but not 96-97
well it is a early 96 so idk if that might make a difference
does that vin lookup site tell you if it has cruise or not?
Doesnt matter.
And the ones Ive seen without it, im not 100% sure it wasnt removed later in life. Even those years, I doubt there was a delete option for it.
lol I knew wat it was as soon a i saw the pic. When i read the title the first thing i thought was oh shit another fel pump test wire or hoo light thead :lol: :willynilly:.
:peace:
:peace:
I would have lost hope in humanity and shot myself had it been another fuel pump test lead thread :willynilly:
