T3 ideas (mention your turbo swap dream)
Just starting a thread and seeing what people have studied or even used on upgrading their TGPs. Stock crossovers and downpipes are not a limitation to input here either.
True that would be nice! But what about the idea altering so you can run a more common line with more options? I have been pondering if I can come up with a crossover/down pipe set-up that can be a kind of conversion kit for us TGP folk.
Anything is possible with a welder... I want a 3" downpipe but Im not sure if Ill really gain that much from it. Probably just a faster spool but thats not a problem with a t25
This is true. I have a T28 hybrid already and and going to experiment with a T3/T4 set-up next and see how it goes. With the larger set-up a 3" down pipe would be ideal I think.
you can kind of funnel it out an start with 2" to 2.25" to 2.5" to 3". jump up one size on each bend. there is an article on this topic by an engineer from garrett who recommends doing it this way.
I am still working on my 3" dp for my gt2871r and it starts off with a 2" mb ss 30 degree bend on a 3/4" t-25/28 flange.
at the outlet of the turbine the pipe only really needs to be a little wider than the diameter of the exposed turbine. then you can funnel it out anywhere from 7 to 14 inches downstream and be fine.
Interesting... Is that to regulate at least a minor sense of back pressure? No back pressure would be horrible but that suggestion is very logical.
I guess backpressure is not needed with a turbo, but its still good to have it funneled out to a big exhaust. the stock exhaust is pretty small already but as we know it is still pretty good and decent power can be made. 2" mandrel bend on that first bend is still going to be bigger than the stock dp.
  • 2 weeks later...
I had a 3" DP on my T25, there's a few flanges for the t25 shape that allow a crushed 3" pipe to fit. It's this style of flange:
T25%20oval%20DP%20flange.jpg with essentially this pipe:
I just used a 3" mandrel bend and a vice because of the master cylinder location, but you get the idea.
You could even use something like this:
But clearance around things may be tight.
Back pressure is not needed after the turbo. The engine sees plenty, if not too much back pressure from the turbo, so there's no worries there. Any backpressure after the turbo essentially lessens the work done by the turbo, decreasing efficiency.
I'm in the process of building a T3 setup. I have a strange setup so I'm not sure if I would have gone the same route with a TGP, but for my 3x00 hybrid 2.8 it turned out that the best T3 turbo for me was a GT3271. If I had the extra displacement, I could probably have run a T3/T04e 50 trim, but I was pushing too close to the surge line with a 2.8. At any rate, I will be fabbing a T3 crossover to TGP manifolds shortly (As soon as parts arrive). I'll probably post progress either here or on TGP forums as it happens.
FWIW a GT2871r would have been a great upgrade too, but too $$$ for me. Plus I needed to fab a new x-over anyway because stock turbo location was giving me trouble with my 3400 top swap tb location, and completely prevented me from running the 3500 UIM with LX5 tb.
after reading this I may just throw my GT2871R on one of my TGPs and just fab up another DP and crossover then for my 88 when I turbo it.
no I haven't even had a chance to try it out yet. :redface:
Where can these flanges be purchased? also the 3" pipe adapter thing.. lol I would like to make a DP for my car and thats a nicee flange.. better than what i have seen
This is what I was trying to do with this thread. Hopefully even more input can be obtained.
The two flanges can be bought from a variety of vendors online. I can't remember where I got mine personally, but I know ATP turbo has them, though their prices may be high. http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=ATP-FLS1
As far as the transition pipe, I'd go with the 3" pipe in a vice method. That's what i did, and it's very cheap. Hammering it to be reasonably round takes some time, but overall not hard at all. They do exist pre-made, but again just check the internet, i'm sure lots of vendors have them.
Edit: ATP has that transition too bottom of the page: http://www.atpturbo.com/mm5/merchant.mvc?Screen=CTGY&Store_Code=tp&Category_Code=ATP-FLS2
