douellette Posted March 11, 2010 Report Posted March 11, 2010 the cat converter after going up hills? idk if its just cause its a new cat (installed it within 6 months ago), or if its already going bad somehow. Its a "high flow" one made by a brand called Flowmonster. Quote
CSI_MuNkY Posted March 11, 2010 Report Posted March 11, 2010 Chances are if it was an after market "high flow" it was probably bad before you bought it... The magna flow ones are complete garbage. But yes, a new cat will smell for the first little while, although it should smell any time you get into the throttle, not just on hills... What does it smell like? Jamie Quote
douellette Posted March 11, 2010 Author Report Posted March 11, 2010 Chances are if it was an after market "high flow" it was probably bad before you bought it... The magna flow ones are complete garbage. But yes, a new cat will smell for the first little while, although it should smell any time you get into the throttle, not just on hills... What does it smell like? Jamie whatever it is they smell like, sulfer i think it is? i havnt really noticed it at other times, ive only noticed it once i get to the top of a hill. Quote
RobertISaar Posted March 11, 2010 Report Posted March 11, 2010 adding more throttle will heat up a cat pretty quickly... if you go far enough, the PCM will actually richen up the AFR and add spark as an attempt to cool it down. Quote
runt Posted March 11, 2010 Report Posted March 11, 2010 Chances are if it was an after market "high flow" it was probably bad before you bought it... The magna flow ones are complete garbage. Jamie The Magnaflow ones aren't really a true "cat". It's more like a hollow void to help pass emissions. At least that has been my understanding from talking to people in the past. Although, I've never had any smell in my car. Inside or out. Quote
oscar_wilde Posted March 11, 2010 Report Posted March 11, 2010 Might want to check for exhaust leaks if you smell it really bad. Otherwise the increased load would probably heat it up really fast and cause a bit of odour. Quote
douellette Posted March 11, 2010 Author Report Posted March 11, 2010 Might want to check for exhaust leaks if you smell it really bad. Otherwise the increased load would probably heat it up really fast and cause a bit of odour. i know it leaks a little bit AFTER the cat, but i dont think that would effect it. Quote
WhatTheFehl Posted March 11, 2010 Report Posted March 11, 2010 My car smells like burning oil when it gets up to operating temperature, but I check all the fluids regularly and I am never low. I've kind of just learned to ignore it... Quote
