Rabbi Posted March 9, 2010 Report Posted March 9, 2010 the highbeam switch is apparently bad in my z34. I Cant turn my bright lights off, It doesnt click when its supposed to. Where do i go about buying a highbeam switch? I seen nothing on autozones website lol its a 1992 lumina z34 Quote
AL Posted March 9, 2010 Report Posted March 9, 2010 I am pretty sure that its part of the Turn Signal Switch Quote
Drummer Posted March 10, 2010 Report Posted March 10, 2010 I've had this happen to my Z34 also a long while back. The switch got jammed or stuck or something and wouldn't release so all i had was high beams. Pretty easy to replace. Quote
Robby1870 Posted March 11, 2010 Report Posted March 11, 2010 This is the part at autozone: http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=19172_0_0_&skuDescription=Duralast+/+Dimmer+Switch&brandName=Duralast&displayName=Dimmer+Switch&categoryNValue=&sortType=&store=1296&isSearchByPartNumber=&fromWhere=&fromString=&counter=0&itemId=133-0&navValue=15700133&filterByKeyWord=&productId=19172&searchText=&categoryDisplayName=Electrical+%26+Lighting&parentId=57-0 It's called a Dimmer Switch. Also, before replacing it, make sure the rod hasn't just come out the switch. This happened to me once after replacing a turn signal switch. I guess I accidentally bumped this and knocked the rod out without knowing it. Very easy to replace though. You'll probably have to drop the top two bolts holding the column up to get a little more room. Quote
rockfangd Posted March 11, 2010 Report Posted March 11, 2010 I am pretty sure that its part of the Turn Signal Switch It is not. Sometimes the rod comes out of the switch and it gets stuck either on high or low, nd also the high beam switch is adjustable so sometimes it can slide back and not work properly. Pretty much you can feel tension but nothing happens Quote
AL Posted March 11, 2010 Report Posted March 11, 2010 I am pretty sure that its part of the Turn Signal Switch It is not. Sometimes the rod comes out of the switch and it gets stuck either on high or low, nd also the high beam switch is adjustable so sometimes it can slide back and not work properly. Pretty much you can feel tension but nothing happens I see, Thats good to know Quote
White93z34 Posted March 11, 2010 Report Posted March 11, 2010 I am pretty sure that its part of the Turn Signal Switch It is not. Sometimes the rod comes out of the switch and it gets stuck either on high or low, nd also the high beam switch is adjustable so sometimes it can slide back and not work properly. Pretty much you can feel tension but nothing happens Exactly what I was going to say, its easy to adjust once you lower the column down. Quote
paulo57509 Posted March 20, 2010 Report Posted March 20, 2010 Try operating the dimmer switch with the steering wheel tilted in different positions. Sometimes this will compensate for a mis-adjusted switch. Works for me. Quote
