dodgeman Posted March 9, 2010 Report Share Posted March 9, 2010 I dont know where it is. I have a ub3 dash i am installing and need to know where it is so i can run the tach wire. thanks Quote Link to comment Share on other sites More sharing options...
Galaxie500XL Posted March 9, 2010 Report Share Posted March 9, 2010 Bottom of the dash, to the right of the steering column. Quote Link to comment Share on other sites More sharing options...
dodgeman Posted March 10, 2010 Author Report Share Posted March 10, 2010 I have a 94 vert, and was installing the ub3 following the pin outs i could find on here. i have found 2 that were different and then i look at my plug and it is even different from the 2 guides. most of the pins were correct from what i can tell, but i have some left over and a few things dont work. The left over wires are from the plug on the ub3. d-16 battery power mem to cluster orng d-9 english/ metric switch. but that works on my cluster now c-13 iknow that is for my tach but not sure if something else goes there c-10 display dim c-9 not used c-6 shift indicator for manual shift my abs light will not come on. one of the guides i have says it is d-13 grn/black but it issupposed to go to c-5 gry/wht all of the wires i have spliced so far have matched in color. the base diagram shows d-13 as anitlock and it is g/wht, but mine is grn/blk I am more confused now then when i started. Quote Link to comment Share on other sites More sharing options...
dodgeman Posted March 11, 2010 Author Report Share Posted March 11, 2010 Sorry for being such and idiot, but i tried to hook up a wire to c-13 to what i thought was the aldl. I looked under my dash next to the steering column and see a black box with wiring harness in and wiring harness out. I found one orange wire. It was a lot bigger than the rest of the wires so i tried that, got nothing. found another that was kinda brownish orange and tried that, nothing. There is another box beside this thing that is silver. Am i even in the right place. Everything else works but the tach. Any help would be great, thanks Quote Link to comment Share on other sites More sharing options...
3.1cutlass Posted March 11, 2010 Report Share Posted March 11, 2010 Now that we got that covered, are you sure you have the right wire on the dash? Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted March 11, 2010 Report Share Posted March 11, 2010 I merged your threads. There is no need to make three threads for the same project. Quote Link to comment Share on other sites More sharing options...
dodgeman Posted March 11, 2010 Author Report Share Posted March 11, 2010 sorry, didnt know. i have the correct wire on the cluster, it is c-13. and i spliced into the only orange wire that i could see on that connector and it would not work. That is why i thought i was connecting to the wrong wire. by the way. that orange wire is a lot bigger than the rest of them. am i looking at the right orange wire? and sorry about the caps, wont ever happen again Quote Link to comment Share on other sites More sharing options...
rockfangd Posted March 11, 2010 Report Share Posted March 11, 2010 Ok the wire you need to tap into is a small gauge tanish orange wire. It is located in the back side of the slot where a scantool plugs into right above the right leg. . The wire is the ALDL chatter wire. Unless you have something incorrect at the cluster it will definately work Quote Link to comment Share on other sites More sharing options...
dodgeman Posted March 11, 2010 Author Report Share Posted March 11, 2010 found it, and go it connected and the tach works now, but it shows redline at 5500. i thought it was 6000 or 6500? oh well, at least it works. tomorrow i get my oil changed and get the correct switch for the oil pressure. Quote Link to comment Share on other sites More sharing options...
