Q-Ball Posted March 7, 2010 Report Posted March 7, 2010 Well, I've come to my knowledge that Regals and Grand Prix's may have different radiators. I've looked on a bunch of Grand Prix's and they seem to have a twist plug, where as my Regal uses a 1/4" square drive to turn the plug. Anyways, my problem is, i can turn the plug, but how do you get the plug out? I've tried pulling it out, but I cant get it. This site has some pics of what the plug looks like, but I'm still at a stand still since I cant get the damn thing out. http://www.automotiveforums.com/t936984-how_do_i_drain_the_radiator_and_cooling_system_flush_for__97_and_up_regal_century.html Applicable to '97 and up Buick Regal and Century and '97 - '03 Pontiac Grand Prix 1/4" drive tool and drain plug removed from radiator for illustration purposes Coolant being drained Location of drain plug on removed radiator Quote
sl3196 Posted March 7, 2010 Report Posted March 7, 2010 I couldn't ever get mine to work either so I just popped off the lower hose. Quote
1990lumina Posted March 7, 2010 Report Posted March 7, 2010 You don't remove that plug 100%. Keep twisting it till coolant starts draining out. It's a very fine thread so might take a few turns to get things rolling. Don't take it out al the way you'll have a huge mess everywhere. Quote
Q-Ball Posted March 8, 2010 Author Report Posted March 8, 2010 Yeah, I just pulled off the lower rad hose. Than I sucked a bunch of it out with my shopvac. Put in my rad flush, flushed it all out and refilled it and seems to be working great! Quote
Regal_GS_1989 Posted March 8, 2010 Report Posted March 8, 2010 Maybe an L67 Thing? My Regal has the little twist thing to drain the rad. Quote
OldTinkerer Posted November 18, 2012 Report Posted November 18, 2012 My plug looks like the one at the top. At first it appeared that the 1/4 in drive would not work but pressing in harder and applying force off-center, it finally broke loose. After turning it about a bazillion times I decided it was enough. Taking a screwdriver blade to the space between the radiator and the plug I was able to pop it out so that fluid began to run. Continuing pulling it out by hand removed it completely. It did not appear to have any fine threading and really seems to act more like a pop in and out affair. Quote
GtpKo Posted November 19, 2012 Report Posted November 19, 2012 Must be an L67 thing, my GTP had a 1/4" drive plug like that. I tried to get mine out, but was too nervous it would break. Lower hose works fine and you don't have to worry about a tiny nylon plug that strips on you. Quote
