doesnt like to start when hot
hi everyone, i have a 89 cutty supreme, 3.1 v6, sometimes after driving, after its warmed up, it doesnt wanna start again. i had to wait like 5 hours the other day. :( 2 days after that it flashed the code 45(rich exhaust) but didnt say. anyideas what this could be?
also, last week the car battery went mysteriously dead (new battery). whats the regular running voltage. mine is 13.3-14.5v
When you mean, "wont start" do you mean it cranks and wont catch or doesnt make a sound at all when you turn the key
Robby
Alright, here are some suspects:
Fuel pump
Crank sensor
Coils
ICM
So it runs fine when hot, just if you stop it, it wont start again. Does it do fine at high rpms? If so, it maybe the fuel pump. I have heard of this condition before and it ended up being the fuel pump. Check your fuel pressure with the motor hot, but turned off, but with the key in the on position. It should be around 41-47psi. That is at the schader valve on the fuel rail
Robby
Could be a couple of things; let's see...
If it's running rich, then the either the O2 sensor has died or is not sending a signal.
Other it could be poor spark / wires, or even the ignition coil.
But when it's warm it doesn't idle? Could be a weak fuel pump or fuel pressure regulator.
EFI engines don't encounter vapor lock, but with a faulty pump or regulator the motor can.
I would test these systems and see where / when you can isolate the situtation.
Best of luck to you!
- Erik
EDIT: Damn you Robby, you're quick...
Sure am! At least we said the same things........
Robby
Robby
that's what she said too :lol:
Robby
HAHAHAHAHAHAHAAHAHHA!!!!!!!!!!!.......................ASS!!!!!!
Robby
