capcrunk Posted March 1, 2010 Report Posted March 1, 2010 yep as the title says the trunk is super stiff and when u do close theirs a little movement on the left side when u press down it which is leaving a gap which is allowing water in the trunk the dealer who had it said to spay some dw40 on the spring ? and the trunk can be adjust ? any help would be appreciated Quote
DavidHowell3633 Posted March 2, 2010 Report Posted March 2, 2010 Regarding the stiffness, mine was that way when I bought it and Yes, WD-40 can help. I also loosened the spring tension with the adjusting nut and after the stiffness was overcome by the WD-40, began retightening until I got it where I wanted it. Just try to keep both sides adjusted the same. When I pop the trunk, it releases, but catches about two inches high rather than flinging completely open. Regarding the pushing down on one side, I haven't experienced that so I can't help. Quote
capcrunk Posted March 2, 2010 Author Report Posted March 2, 2010 thanks will do that on side is a little up that's what i mint there was movement Quote
DavidHowell3633 Posted March 18, 2010 Report Posted March 18, 2010 I haven't looked recently, but I would assume that there are probably a couple of bolts on each side that when loosened would allow some adjustment. I had to do that on my 67 Cougar. Quote
