hoodilio Posted September 23, 2003 Report Posted September 23, 2003 Ok so i have been have that smokin steering column off and on for a while back, and most of you guys told me that it was a bad turn signal switch mechanism. Do any of you guys know the AC Delco part number for one for a 1993 Cutlass Supreme, also how hard is it to do the job, details and tips might help. Thanks guys. Quote
PaPaPooh Posted September 23, 2003 Report Posted September 23, 2003 ok there is 2 of them 1: Without RPO ELEK ACSRY CONT SYS(UK3) ^ STRG COL(NP7)(EXPORT) part # D6259 2: With RPO ELEK ACSRY CONT SYS(UK3) Without RPO STRG COL(NP7)(EXPORT) part # D6274 i found there at http://www.acdelco.com/html/catalog/index.htm good luck Quote
hoodilio Posted September 23, 2003 Author Report Posted September 23, 2003 what is the "RPO STRG COL(NP7)(EXPORT)" Quote
hoodilio Posted September 23, 2003 Author Report Posted September 23, 2003 i meen how do i know which one i need? Quote
PaPaPooh Posted September 23, 2003 Report Posted September 23, 2003 i have no clue. maybe someone else with experiance with that can help? Quote
Redfox340 Posted September 23, 2003 Report Posted September 23, 2003 what is the "RPO STRG COL(NP7)(EXPORT)" RPO code: UK3 - Electronic System, Accessory Cont RPO code: NP7 - Steering Column, EEC Approved Means that it was used in Canada and other countries outside the United States. Basically, you'll want #2 if you DON'T have BOTH RPO codes in the trunk of your car. - Erik * thanks to Shawn for the RPO codes - W-Body.com - RPO codes * Quote
