hell_raiser Posted February 21, 2010 Report Posted February 21, 2010 i know this car has a stock amp somwere cuz my sterio wires dont look at all as whats posted on the net no speaker wire coulors Quote
xtremerevolution Posted February 21, 2010 Report Posted February 21, 2010 I don't believe you have an additional amp anywhere. Everything should be running right out of your head unit. Quote
RobertISaar Posted February 21, 2010 Report Posted February 21, 2010 yeah, i'm not seeing any diagrams for a factory amp in a 94 regal. Quote
hell_raiser Posted February 21, 2010 Author Report Posted February 21, 2010 mmm maby ill dig around more lol its dark out ill go out and double check thanks guys Quote
hell_raiser Posted February 21, 2010 Author Report Posted February 21, 2010 yup i was rite there is an amp under my dash on the passangers side! im going out to take pics! Quote
xtremerevolution Posted February 21, 2010 Report Posted February 21, 2010 yup i was rite there is an amp under my dash on the passangers side! im going out to take pics! This I've got to see. Quote
Crazy K Posted February 21, 2010 Report Posted February 21, 2010 94 is still the mulitpart radio, isn't it? the radio would have an amp behind the glovebox area. Quote
hell_raiser Posted February 21, 2010 Author Report Posted February 21, 2010 yes sir its a crazy pita to put a deck in Quote
hell_raiser Posted February 21, 2010 Author Report Posted February 21, 2010 anyone have a diagram for all the parts to the stock system ? Quote
RobertISaar Posted February 21, 2010 Report Posted February 21, 2010 which radio does yours have? i'm seeing at least 2 radios were availible for 1994. check your RPO codes, if you see UM7 or UM6, then i'll know which diagrams to post. Quote
Crazy K Posted February 22, 2010 Report Posted February 22, 2010 which radio does yours have? i'm seeing at least 2 radios were availible for 1994. check your RPO codes, if you see UM7 or UM6, then i'll know which diagrams to post. Actually, can you post both? I have a project in mind... Quote
RobertISaar Posted February 22, 2010 Report Posted February 22, 2010 which radio does yours have? i'm seeing at least 2 radios were availible for 1994. check your RPO codes, if you see UM7 or UM6, then i'll know which diagrams to post. Actually, can you post both? I have a project in mind... very well. 1 and 2 should be UM6, 3 and 4 should be UM7. no idea what the differences are. Quote
Crazy K Posted February 22, 2010 Report Posted February 22, 2010 thanks! why did I ask? because deluxe 88-94 CS radios are modular and use the same amp set up as the regals.... EXCEPT... the amp is mounted as part of the radio, making it appear to be a single whole unit. Quote
