AL Posted February 18, 2010 Report Posted February 18, 2010 Classmates car problem... His radio stays on after the car is turned off and key out of the ignition until the door is opened and then it shut off but when you close the door, the radio comes back on... He said it never used to stay on after the key was removed until today... He has an aftermarket radio is a Sony, thats all the details he knows about the radio... Nothing else works except the radio when the key is out. Quote
WhatTheFehl Posted February 18, 2010 Report Posted February 18, 2010 Classmates car problem... His radio stays on after the car is turned off and key out of the ignition until the door is opened and then it shut off but when you close the door, the radio comes back on... He said it never used to stay on after the key was removed until today... He has an aftermarket radio is a Sony, thats all the details he knows about the radio... Nothing else works except the radio when the key is out. Sounds like a fucked up RAP module, but I'm not an expert. Quote
Addicted2bass Posted February 18, 2010 Report Posted February 18, 2010 Thats a strange one. A bad RAP module is a possibility though. Quote
slick Posted February 18, 2010 Report Posted February 18, 2010 Wouldn't/doesn't the RAP module also keep the interior lights on too, or am I not remembering correctly? When he opens and shuts the door, do the interior lights shut off? Quote
AL Posted February 19, 2010 Author Report Posted February 19, 2010 Forgot to ask him, or maybe he didnt notice it cause he didnt mention them Quote
Addicted2bass Posted February 20, 2010 Report Posted February 20, 2010 Im not sure if it keeps the lights on or not. But it should keep power to the windows so they could still be rolled up or down untill you open the door. Quote
problemlumina Posted February 20, 2010 Report Posted February 20, 2010 this is my car and never mind it just stopped and started actin fine...and no the dome light nor the windows were on/work with the key out Quote
problemlumina Posted February 23, 2010 Report Posted February 23, 2010 alright so the lumina is back at it again the dome light goes off when u shut the door and the widows do not work when the key is out either... any other suggestions? Quote
slick Posted February 23, 2010 Report Posted February 23, 2010 Whether you know how to do it or not, while the radio is still working, pull it out, and check for power at the 12V+ ignition (switched) wire. That will tell you if it is a relay/fuse/wiring issue, or if the radio has a loose connection on the inside. Quote
carkhz316 Posted February 23, 2010 Report Posted February 23, 2010 Didn't see the what kind of car it was til now Just to let anyone know, unless this has already been established, there is no Retained Accessory Power on Luminas or Montes. Whether you know how to do it or not, while the radio is still working, pull it out, and check for power at the 12V+ ignition (switched) wire. That will tell you if it is a relay/fuse/wiring issue, or if the radio has a loose connection on the inside. Second this. Someone has probably been in there switching factory HU to aftermarket or vice-versa. Is it a factory or aftermarket deck? Could be as simple as someone mixed up the constant 12V+ with the accessory wire in the radio harness. Quote
AL Posted February 23, 2010 Author Report Posted February 23, 2010 He has an aftermarket radio is a Sony, thats all the details he knows about the radio In original post... It is an aftermarket radio Quote
slick Posted February 23, 2010 Report Posted February 23, 2010 Oh, well do as I said in my post. Either the wiring is hacked to hell (didn't use the fancy plug that plugs right into the factory harness.... I still don't know why people insist on saving the $7 that it costs at Walmart for that plug), or since it is a Sony, it's just a piece of shit. Quote
carkhz316 Posted February 23, 2010 Report Posted February 23, 2010 He has an aftermarket radio is a Sony, thats all the details he knows about the radio In original post... It is an aftermarket radio Whoops. Sorry. Kinda skimmed parts. Quote
problemlumina Posted February 23, 2010 Report Posted February 23, 2010 ya idk it does it randomly and it has worked for the past 3 years (as long as my woman has had the car)and just started doin it last week but is not doin it...today but ill try checkin the wiring if it does it again Quote
