94GPGTP Posted February 17, 2010 Report Posted February 17, 2010 I need the pulse rate for the speedo for a 90 TGP and a 89 GP LE 2.8 5 spd.. trying to get my speedo corrected to the 5 spd tranny and i dont know the pulse rate.. as of right now im 10 MPH off.. Quote
BXX Posted February 17, 2010 Report Posted February 17, 2010 I know the signal should be 4000 pulse per mile to the PCM. From there the PCM uses gearing calculations to send a signal to the cluster. So you'll need a chip burned (im assuming you dont burn your own chips) Quote
RobertISaar Posted February 17, 2010 Report Posted February 17, 2010 the later setup used a 4000PPM signal, but thses ones range anywhere from ~40,000 to less... if you can get me the BIN(or at least the BCC) i can try and tell you what the road speed constant and pulse divisor is for both... Quote
mfewtrail Posted February 18, 2010 Report Posted February 18, 2010 There's some discussion on this subject here that should help you: http://www.tgpforums.com/index.php/topic,2708.0.html Quote
