94 olds vert Posted March 24, 2010 Report Posted March 24, 2010 Are the pics working? Or is it just me? Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 91LuminaEuro said: Not workin for me either. 94 olds vert said: Are the pics working? Or is it just me? haha sorry guys, i posted the reply while i was waiting for the pics to upload. pics are up now. Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 well, ran into a problem. for some reason even after letting it sit all night, the resin didnt dry..its still liquid lol Quote
GnatGoSplat Posted March 24, 2010 Report Posted March 24, 2010 Damn, the molds look really good! Too bad the resin didn't harden. Did it come with any documentation that mentions how long it takes? Is it a 2-part resin that needs a hardener added? I'm gonna have to make some OEM clears for my 89 if that works out for you! Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 GnatGoSplat said: Damn, the molds look really good! Too bad the resin didn't harden. Did it come with any documentation that mentions how long it takes? Is it a 2-part resin that needs a hardener added? I'm gonna have to make some OEM clears for my 89 if that works out for you! yeah its got 2 ingredients that you mix together, which i did in equal amounts. Says its supposed to dry in an hour or so. also says if its thin to put it in an oven for like a couple of hours. but i had my little electric heater on it all night (from 9pm to 7am). Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 alright, im startin to lose my patience for this haha heres some pics on the results, the clear thing in the pic is the stuff i let cure all night - right color, but still soft/flexible. the white one is another companys material. let it cure for about 20 mins - wrong color, and the right hardness. Quote
GnatGoSplat Posted March 24, 2010 Report Posted March 24, 2010 That's too bad, could the ratio of the mixture for the clear stuff not be 1:1? It's odd it wouldn't set up in the amount of time they specify. The white one looks like it has a lot of imperfections. Were those air bubbles, or are those problems also in the original mold? I had a feeling like 99% of the tutorials out there, they make it look WAY easier than it really is! I bet this kind of thing takes a lot of practice. Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 GnatGoSplat said: That's too bad, could the ratio of the mixture for the clear stuff not be 1:1? It's odd it wouldn't set up in the amount of time they specify. The white one looks like it has a lot of imperfections. Were those air bubbles, or are those problems also in the original mold? I had a feeling like 99% of the tutorials out there, they make it look WAY easier than it really is! I bet this kind of thing takes a lot of practice. well those dimples or whatever you want to call it are from the leftover resin from the first try, i just wanted to quickly try this other stuff to see how it came out. but if i try anything else, im going to have to buy more silicone mold making material because this one isnt working so well and i need to make a separate mold for the other side. i dont know, what do you guys think i should do? Quote
bodeen2007 Posted March 24, 2010 Report Posted March 24, 2010 keep trying. it's a process of trial and error . it took me months of trying to figure out how to cast stuff when i was building models but i got to the point where i could do it in my sleep . U are more brave then me i won't even try to do automotive parts the closest i've ever came was doing a set of wheels for my evader r/c truck.... Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 moo cow disease said: keep trying. it's a process of trial and error . it took me months of trying to figure out how to cast stuff when i was building models but i got to the point where i could do it in my sleep . U are more brave then me i won't even try to do automotive parts the closest i've ever came was doing a set of wheels for my evader r/c truck.... yeah but thing is, is that its super expensive. http://alumilite.net/ProdDetail.cfm?Category=Silicone%20Rubber&Name=High%20Strength%202%20(HSII) mold material http://alumilite.net/ProdDetail.cfm?Category=Casting%20Resins&Name=Alumilite%20Clear resin Quote
douellette Posted March 24, 2010 Author Report Posted March 24, 2010 and here is the guide im using. http://www.alumilite.com/HowTos/TailLightMoldingNoEquipment.cfm Quote
bg35765 Posted March 24, 2010 Report Posted March 24, 2010 douellette said: yeah but thing is, is that its super expensive. I would suggest that you start with something small that you have around the house -- but that has enough texture to test that the resin will do what you want. Maybe a 1" sea shell that has the ribbed texture on the outside, but is smooth on the inside. Or something along those lines. Once you get the hang of that, then try something a little bigger -- maybe a sea shell 3" wide. That way you work your way up to the corner light while minimizing wasted material. Quote
IRONDOG442 Posted March 24, 2010 Report Posted March 24, 2010 Youre a regular god damned genius Gump! Quote
intern8tion9l Posted March 26, 2010 Report Posted March 26, 2010 those molds look great. hope you perfect it, i bet you'd get a bunch of buyers Quote
douellette Posted March 27, 2010 Author Report Posted March 27, 2010 i might have discovered something. i was reading the instructions on the clear resin mix (the one that didnt work) and it says to mix it in equal amounts..BUT it says to do it in weight not by sight. sooooo, i just ordered a cheap little scale so i can try to weight each amount out. The scale will be here in about a week or so. Quote
ss427 Posted March 31, 2010 Report Posted March 31, 2010 If you can get your hands on a pressurized chamber I would recommend one. This will eliminate any bubbles and air pockets as the material cures. You can also make one from a plaster bucket. Quote
mra32 Posted March 31, 2010 Report Posted March 31, 2010 dont you want a vacuum chamber for this, at least for mixing?? But that would be a good idea as well (but im fairly certain its vacuum, and vacuum is harder to come by than compressed air) Quote
ss427 Posted March 31, 2010 Report Posted March 31, 2010 I think it can be done either way, but I am going from memory of a conversation I had a while back with a buddy who used to work in advertising and cast stuff every day. Quote
douellette Posted March 31, 2010 Author Report Posted March 31, 2010 mra32 said: dont you want a vacuum chamber for this, at least for mixing?? But that would be a good idea as well (but im fairly certain its vacuum, and vacuum is harder to come by than compressed air) the stuff i bought is designed so that you dont have to buy a pressure/vacuum chamber or whatever. Quote
douellette Posted April 4, 2010 Author Report Posted April 4, 2010 sucess!! i have successfully made a clear corner lense! lol granted its not perfect, but ive figured most of the process out. heres some pics of the results: Quote
91LuminaEuro Posted April 4, 2010 Report Posted April 4, 2010 Wow! looks pretty darn good! Keep up the good work!1 You should have these perfected very soon! Quote
