xtremerevolution Posted February 12, 2010 Report Posted February 12, 2010 Real quick, does anyone know the torque specification for the bolts on the 4T60E side cover? Also, is there a specific tightening pattern? I seem to have misplaced my haynes manual... Quote
Night Fury Posted February 12, 2010 Report Posted February 12, 2010 Are there nuts AND bolts holding the trans side cover on? My thing says: Install the case side cover pan. Install the gasket. Install the bolts. Tighten Tighten the bolts to 11 N·m (97 lb in). Tighten Tighten the nuts to 8 N·m (71 lb in). There are no patterns shown Quote
Crazy K Posted February 12, 2010 Report Posted February 12, 2010 You should be looking at the FSM. I have one for 96 and 94... if you call I could look it up.. Quote
xtremerevolution Posted February 12, 2010 Author Report Posted February 12, 2010 Got it. Thanks Ken! 8 ft-lb. Quote
xtremerevolution Posted February 12, 2010 Author Report Posted February 12, 2010 Buck, what's 97 in-lb in ft-?lb Quote
Night Fury Posted February 12, 2010 Report Posted February 12, 2010 Buck, what's 97 in-lb in ft-?lb 8 Quote
xtremerevolution Posted February 12, 2010 Author Report Posted February 12, 2010 Buck, what's 97 in-lb in ft-?lb 8 That's what I used. I just needed a second opinion. Doesn't matter who it is, I like to be 100% sure before I go off tightening bolts that need to support half the engine and transmission's weight. Quote
GnatGoSplat Posted February 12, 2010 Report Posted February 12, 2010 Buck, what's 97 in-lb in ft-?lb How many inches in a foot? Schurkey 1 Quote
Novice Posted November 23, 2022 Report Posted November 23, 2022 I know I'm far behind but any idea what the four T40 screws at the bottom should br torqued???? Quote
