douellette Posted February 8, 2010 Report Posted February 8, 2010 is there a way to wire up a toggle switch to the factory fans and still have them function like normal and not have the check engine like come on at the same time? currently i have a switch wired up to one of the relays for the fans ( i cant remember which one) but it makes the check engine like come on (even if i dont turn the switch on) Quote
mfewtrail Posted February 9, 2010 Report Posted February 9, 2010 anyone? Read over this page. http://www.backinblackgp.com/Manual_Fans.htm Quote
douellette Posted February 9, 2010 Author Report Posted February 9, 2010 anyone? Read over this page. http://www.backinblackgp.com/Manual_Fans.htm that is very confusing...so the only thing that is currently in my car in that picture is the relay center, pcm, and the green & blue wires? and then everything else in the picture is what i have to wire in? Quote
GOT2B GM Posted February 9, 2010 Report Posted February 9, 2010 W's should be similar http://www.v6z24.com/howto/fan Quote
douellette Posted February 9, 2010 Author Report Posted February 9, 2010 W's should be similar http://www.v6z24.com/howto/fan i think that may be how i have it wired up now and it turns the check engine light on. and i think it doesnt on those cavi's cuz they are OBD1 Quote
jake91 Posted February 10, 2010 Report Posted February 10, 2010 http://www.w-body.com/upgrades/manualfancontrol.html Quote
mfewtrail Posted February 10, 2010 Report Posted February 10, 2010 that is very confusing...so the only thing that is currently in my car in that picture is the relay center, pcm, and the green & blue wires? and then everything else in the picture is what i have to wire in? Straight from the text above the image: "You will leave the stock relays in the relay center. There is actually no need to even open up the cover. This modification will require 3 additional relays shown below that can be purchased at almost any automotive parts store. They are most commonly used to control auxiliary wiring." Quote
douellette Posted February 10, 2010 Author Report Posted February 10, 2010 alright well i just ordered 3 30A relays from ebay. Quote
