W-body Acrynoms
I want to add a list of acronyms and their meanings to the new site design, to help all the newbies learn how we communicate around here.
Some examples are:
B4U
B4M
STE
TGP
FE3
etc.
I'm looking for help in this, I don't know them all. So post up the acronyms and their meanings that you know and I'll put them all together for the new site!
Some of these reused and vary from model to model, so I'll give these as I know (related to Grand Prixs).
B4U = The 91-96 "wide body" aero kit available on GTP's and higher optioned SE's
B4M = The 89-90 Turbo Grand Prix-specific aero kit. Included composite headlights rather than sealed beam "mini quads".
STE = Special Touring Edition. Trim level that ran from 1990-1993 on the Pontiac Grand Prix. Included upgraded interior trim (seats, door panels), specific stereo systems, and specific trunk panel applique. In 1990 was available with the 3.1 Turbocharged V6 as an option.
TGP = Turbo Grand Prix. Limited edition trim level from 1989 to 1990. Included model-specific aero body kit as well as an Intercooled Turbocharged 3.1L V6 modified by ASC/McLaren. HUD was specific and only available in the TGP. Custom gauge cluster. Custom transmission and cooler (4T60-HD)
FE3 = Performance suspension. Typically included the stiffest spring rates and biggest sway bars.
CSC = Cutlass Supreme Convertible.
L67 = RPO code for the 3.8 Supercharged V6.
LG5 = RPO code for the 3.1 Intercooled Turbocharged V6.
LQ1 = RPO code for the 3.4 DOHC 24-Valve V6.
LH0 = RPO code for the 3.1L MPFI V6 (1989-1993, 1990-1994 in Luminas).
284 = Refers to the Getrag 284 5-speed transaxle available from 1991-1993 in LQ1-equipped Grand Prix, Cutlass Supreme and Lumina.
282 = Refers to the Getrag 282 5-speed transaxle available from 1988-1990 in Grand Prix and Cutlass Supreme.
Z34 = Trim level available on the 1991-1994 Lumina and the 1995-1999 Monte Carlo. From 1991-1994 included the 3.4 DOHC V6 and specific aero body kit and spoiler. Z34-specific decals. 1995-1997 included the 3.4L DOHC V6 as well as minor exterior modifications. 1998-1999 included the 3800 Series II V6.
B4U - Refers to the "aero" bodykit on 88-96 Grand Prix
B4M - Refers to the more standard, base model 88-96 Grand Prix
STE - Special Touring Edition Grand Prix Sedan made 90-93, Higher options, Had either 3.1 Turbo, 3.4 DOHC, or 3.1
TGP - Turbo Grand Prix made 89/90
FE3 - Sport Suspension
UB3 - Most commonly used to describe the 88-93 Cutlass Supreme Digital Gauge Cluster, however it also denotes the Sport or upmodel cluster on all first generation cars
TDC - Twin Dual Cam, the 3.4 DOHC
AQ9 - Most commonly used to describe the 88-93 Grand Prix Pneumatic seats
DIC/DIS -Driver information Center/System
RSWC - Redundant Steering Wheel Controls
HUD - Heads-Up Display
SES Light - Service Engine Soon light. I duno about other people, but I sometimes use that.
SE - Special Edition
WOT - Wide Open Throttle
TPS - Throttle Position Sensor
ABS - Anti-Lock Braking System (if you didn't know that, then you're probably retarded :P )
STB- Strut tower brace
RKE- remote keyless entry
PM3- powermaster 3 hydraulic master cylinder found in ABS equipped 89-91 W's
ECC- electric climate control
MPFI- multiport fuel injection
SFI-sequential fuel injection
LX5- 3.5 twin cam v6
LA1- 3400
LX9- 3500
FWI- fender well intake
CAI / WAI - cold / warm air intake
x-over- crossover
obd - on board diagnostics
hid - high intensity discharge
dogbone - torque strut
xlaces - crosslace wheels
LIM/UIM: Lower/Upper Intake Manifold
TStar: Torque Star Wheels, available on late model Grand Prixs.
T-Stat: Thermostat
TPS, throttle position sensor
IAC, idle air control
MAP, manifold absolute pressure
DP, downpipe
EGR, exhaust gas recirculation
o2, oxygen
IAT, intake air temp
VSS, vehicle speed sensor
CTS, coolant temp sensor
UD, underdrive
CV, constant velocity
CPS, crank position sensor
t-stat, thermostat
UIM, upper intake manifold
LIM, lower intake manifold
TB, throttle body
cat, catalytic converter
DP, downpipe
o2, oxygen
UD, underdrive
t-stat, thermostat
TB, throttle body
hey, you copied several of those from me :lol:
BYP = base body kit, standard on non-B4U cars.
Also, I think it was Buck that started a thread for engine RPO codes that would be useful.
DP, downpipe
o2, oxygen
UD, underdrive
t-stat, thermostat
TB, throttle body
yeah, you posted a few minutes before me and I didnt feel like editing them out of my post
AND Cutlass Supreme seats, uncertain if the years match, they may have gone up to 1994.
BYP - to describe body style of 1988-1995 Grand Prix coupes without B4U or B4M cladding (BYP was NOT available in 1996).
FFP = Fast Fwd Performance
CO's = Coil Overs
GMPP TA's = GM Performance Parts Trailing Arms
ST Lowering springs = Suspension Techniques Springs
How could anyone forget L32?!?!
L32- Series III Supercharged 3800
