Yup, nothing like getting on the Ohio Turnpike and realizing your doing 75 with no TCC lockup :willynilly:
That was how my afternoon started..
While driving im racking my brain on the diag steps that could cause it to suddenly not work.
-Fluid level.... nope, trans isnt in limp mode, shift 1-2, 2-3, 3-4 perfectly
-Overheat..... nope, its 20 degrees outside and I just got in the car aboot 3 miles prior to hitting I80
-Brake Pedal... I dont have it pressed down any. I lifted up on the pedal....
And theres my TCC lockup :lol: So fuckin cold the brake pedal was kinda sticky causing the brake switch to be just barely activated and the PCM to think I was hitting the brakes..
And before you ask, yes, cruise control was working!!
  Quote
i've never figured out how to adjust that damn switch, so i put a couple layers of duct tape around that part of the pedal.
  RobertISaar said:
i've never figured out how to adjust that damn switch' date=' so i put a couple layers of duct tape around that part of the pedal.
[/quote']
It was the only time it did that.. At least I know if it does it again just to lift up right away..
I havent looked at the wiring of the switch, but the signal for cruise inhibit must be seperate from the brake input to the PCM to unlock TCC, cause like I said, my cruise control was working perfect
I havent looked at the wiring of the switch' date=' but the signal for cruise inhibit must be seperate from the brake input to the PCM to unlock TCC, cause like I said, my cruise control was working perfect
[/quote']
yep, seperate cruise cutout switch, about 3-4" above IIRC...
Could it be that the trans temp just wasn't warm enough for TCC to engage?
My cutty doesn't lock up for the first 10 mins on a cold day.
My car is the same way, It takes about 5 minutes for mine to lockup.
the gtp takes about the same on a Coldish day.
i had that issue for about a year on my old z34 till one day i pulled back on the brake... did I feel dumb.
It normally does that for a few minutes, but it was plenty warm enough as I was aboot 10 miles down the turnpike and still no TCC.
The very moment I lifted on the brake pedal, TCC engaged.
