douellette Posted January 28, 2010 Report Posted January 28, 2010 hi, every once in a while when i take off from a stop the transmission shift erratically from 1st to 2nd. it starts to shift and then there is like a 1 to 2 second delay/lag before it shifts into 2nd. and when it does shift its alot harder/firmer than usual. but it only does this every great once in a while. i changed the transmission fluid this past fall. what could be the cause? anything to worry about? and its a 97 cutlass 3100 Quote
IRONDOG442 Posted January 29, 2010 Report Posted January 29, 2010 Heres a 10 step guide to solve your problem 1. go to http://www.car-part.com 2. search 1997 3. cutlass (after 1988) 4. search for automatic tranmission 5. sory by distance 6. select transmission you'd like 7. drive to junk yard of choice 8. pay for it 9. find someone to install it 10. pray it works Quote
Crazy K Posted January 29, 2010 Report Posted January 29, 2010 Sounds like it could be a bad vacuum modulator. It is on the front face of the transmission and has a metal line plumbed to it. Unhook the line from the modulator, turn the modulator so it's vacuum connector faces down and see if any fluid leaks out. if so, replace. if it doubt, replace it anyhow... and make sure the vacuum line is 100% hooked up. Quote
xtremerevolution Posted January 29, 2010 Report Posted January 29, 2010 Sounds like it could be a bad vacuum modulator. It is on the front face of the transmission and has a metal line plumbed to it. Unhook the line from the modulator, turn the modulator so it's vacuum connector faces down and see if any fluid leaks out. if so, replace. if it doubt, replace it anyhow... and make sure the vacuum line is 100% hooked up. I'll be damned if this works, because I had the exact same problem he's having and spent $900 to have my transmission rebuilt at 144k, and he's nearing right up there. They told me I had burned through my clutch plates. Its probably not coincidence that I did a 100 foot burnout just a couple of months prior. Heres a 10 step guide to solve your problem 1. go to http://www.car-part.com 2. search 1997 3. cutlass (after 1988) 4. search for automatic tranmission 5. sory by distance 6. select transmission you'd like 7. drive to junk yard of choice 8. pay for it 9. find someone to install it 10. pray it works Rob, the answer to all transmission problems is not a rebuild/new trans. Take my shifting into reverse problem, which turns out is nothing more than a parking brake actuator that you can get for under $30 shipped with 2 day shipping. Although your suggestion does make me want to go out and buy a trans to rebuild just for the hell of having a spare one lying around if mine were to ever fail. Quote
IRONDOG442 Posted January 29, 2010 Report Posted January 29, 2010 No youre supposed to laugh when I make a joke not be sad, thts how it works ! Quote
xtremerevolution Posted January 29, 2010 Report Posted January 29, 2010 No youre supposed to laugh when I make a joke not be sad, thts how it works ! Quote
mfewtrail Posted January 30, 2010 Report Posted January 30, 2010 Have you checked the fluid level since you changed it last fall? Quote
douellette Posted February 2, 2010 Author Report Posted February 2, 2010 Ive checked it cold cause i didn't have time to wait to check it warm. but i don't believe its leaking at all. i bought a new "universal GM" modulator valve from advance auto parts, so ill see if replacing that fixes anything. And also idk if it makes a difference or not, but every once in a while when driving i can smell hot tranny fluid. im pretty sure its from my car and not from someone im following. Quote
douellette Posted February 4, 2010 Author Report Posted February 4, 2010 okay i bought the modulator valve, but havnt checked the old one yet or installed the new one. but when i took the new one of the box and pulled the little rubber cap off the end of it, the little rod thingy that goes into the tranny just like fell out of the modulator, is this supposed to be like this? i dont want to take the chance of it falling out and into the tranny. Quote
