Mach 5 Posted January 26, 2010 Report Posted January 26, 2010 Does anyone have a pic of the square hole that needs to be cut in the firewall for the clutch master? I can't seem to find a clear discription or pic of where to make this hole. I removed the booster so I have plenty of space. The plug next to the booster... Is that the hole? I pulled the plug but no idea on what the final product should look like. thanks -Jarek Quote
Crazy K Posted January 26, 2010 Report Posted January 26, 2010 All automatic cars have the hole you see, if the car had a column shift the shift cable would go through that hole. otherwise is gets a sealed grommet. People have been successful in making the hole you speak of into a square hole and having it work fine. Grab a file and give it a go. and someone will have a pic, I am sure. Quote
Mach 5 Posted January 27, 2010 Author Report Posted January 27, 2010 thanks. I think we'll have to use that in a 5 speed swap thread cuz that is a very good pic Quote
