supersniperkilla Posted January 21, 2010 Report Posted January 21, 2010 My alternator is on the fritz and i can tell it is on its way out...i can get a great deal on a remanufactured alternator for $20 but it is for a 3.1 Will this work? Quote
slick Posted January 21, 2010 Report Posted January 21, 2010 Yes it will. I put the alternator from my 88 regal in my cutlass without any real issues. Just had rotate the casing so that the mounting points lined up. No shit??? I could have sworn the mounting points were different. Did they all line up, or just a few? The alternators themselves were identical. I had to unbolt the 2 halves, and rotate the front piece so that the mounting points lined up correctly. I forget which way I had to rotate it,but if you compare a 2.8/3.1 alternator to one from an LQ1, you will see what I mean. The alternator is technically the same, just the angles at which the 2 halves of the case are joined is different. And Yes, all the mounting points were the same. I remember fighting like a bitch trying to get the 2.8 alt to fit on my 3.4 to no avail, then when i got fed up and put it next to the one i had pulled out i saw that it was basically a mirror image of the 2.8 alt. So thats when i rotated the front half of the case and it slipped in like a glove. Quote
GOT2B GM Posted January 21, 2010 Report Posted January 21, 2010 his 94 will have the round CS130D will it not? Quote
GOT2B GM Posted January 21, 2010 Report Posted January 21, 2010 and a 3.1 alternator is a CS130 correct? (3100 is CS130d) Quote
GOT2B GM Posted January 21, 2010 Report Posted January 21, 2010 so a 3.1 alternator will not work on a 94+ 3.4 dohc. Quote
slick Posted January 21, 2010 Report Posted January 21, 2010 Correct. He would need a 3100 alternator, in which he would have to verify that he could rotate the housings. Quote
Crazy K Posted January 21, 2010 Report Posted January 21, 2010 Correct. He would need a 3100 alternator, in which he would have to verify that he could rotate the housings. crazy K in now on a mission...... update: sub-mission 1: appearance match confirmed... sub-mission 2: part number matching 1995 OLDSMOBILE CUTLASS SUPREME 3.1L 189cid V6 MFI (M) : Electrical : Alternator Price Core Total AdviceNSA Part # ALT1400 More Info Amps: 100 Part Image $102.79 $0.00 $102.79 Add to Cart BBB PRECISION Part # N8156 More Info Amps: 100 $109.79 $0.00 $109.79 Add to Cart BBB PRECISION Part # 8156 More Info {Remanufactured - May Not Include Pulley} Amps: 100 $76.79 $36.00 $112.79 Add to Cart ACDELCO Part # 3342423A More Info {#88864254} GENERATOR,(REMAN) WITH NEW REGULATOR; 2 DOORS; DELCO CS130D; 105 AMPS GENERATOR,(REMAN) WITH NEW REGULATOR; 4 DOORS; DELCO CS130D; 105 AMPS $110.79 $15.00 $125.79 Add to Cart ACDELCO Part # 3342423 More Info {105 AMP #10463884, 10463964, 10464074, 19135981, 3211308, 3211416, 3211422} GENERATOR,(REMAN) 2 DOORS; DELCO CS130D; 105 AMPS GENERATOR,(REMAN) 4 DOORS; DELCO CS130D; 105 AMPS Part Image $109.79 $16.50 $126.29 Add to Cart BECK/ARNLEY Part # 1866149 More Info {May Not Include Pulley} Alternator, Remanufactured, 105 Amperes;Serpentine 6 Groove;1 Per Car (Only 3 Remaining) Part Image $98.79 $40.00 $138.79 Add to Cart REMY Part # 21126 More Info {Reman} 100 Amps Part Image $111.79 $50.00 $161.79 Add to Cart BOSCH Part # AL8703X More Info {Remanufactured Alternator - May Not Include Pulley} w/Closed end shield;Refer to Application Notices B103 and B111 Part Image $110.99 $55.00 $165.99 Add to Cart BOSCH Part # AL8704X More Info {Remanufactured Alternator - May Not Include Pulley} w/Open end shield;Refer to Application Notices B103 and B111 Part Image $116.79 $55.00 $171.79 Add to Cart BOSCH Part # AL8704N More Info w/Open end shield;Refer to Application Notices B103 and B111 * Non-stock item--shipping delayed up to 4 business days $127.89 $0.00 $127.89 Add to Cart BOSCH Part # AL8703N More Info w/Closed end shield;Refer to Application Notices B103 and B111 * Non-stock item--shipping delayed up to 4 business days $131.79 $0.00 $131.79 Add to Cart DENSO Part # 2105165 More Info {Remanufactured} * Non-stock item--shipping delayed up to 2 business days Part Image $102.79 $34.00 $136.79 Add to Cart REMY Part # 91522 More Info {Remy Gold} 100 Amps * Non-stock item--shipping delayed up to 2 business days 1995 OLDSMOBILE CUTLASS SUPREME 3.4L 207cid V6 MFI (X) : Electrical : Alternator Price Core Total AdviceBBB PRECISION Part # 81553 More Info {Remanufactured ALTERNATOR} Amps: 105 $71.99 $36.00 $107.99 Add to Cart NSA Part # ALT1401 More Info Amps: 105 Part Image $115.79 $0.00 $115.79 Add to Cart ACDELCO Part # 3342422A More Info {#88864379} GENERATOR,(REMAN) WITH NEW REGULATOR; 2 DOORS; DELCO CS130D; 105 AMPS GENERATOR,(REMAN) WITH NEW REGULATOR; 4 DOORS; DELCO CS130D; 105 AMPS $110.79 $15.00 $125.79 Add to Cart ACDELCO Part # 3342422 More Info {105 AMP #19135980} GENERATOR,(REMAN) 2 DOORS; DELCO CS130D; 105 AMPS GENERATOR,(REMAN) 4 DOORS; DELCO CS130D; 105 AMPS Part Image $109.79 $16.50 $126.29 Add to Cart BECK/ARNLEY Part # 1866146 More Info {May Not Include Pulley} Alternator, Remanufactured, 105 Amperes;Serpentine 6 Groove;1 Per Car (Only 3 Remaining) Part Image $93.79 $40.00 $133.79 Add to Cart REMY Part # 21031 More Info {Reman} 105 Amps Part Image $106.79 $50.00 $156.79 Add to Cart BOSCH Part # AL8704X More Info {Remanufactured Alternator - May Not Include Pulley} Refer to Application Notices B103 and B111 Part Image $116.79 $55.00 $171.79 Add to Cart BOSCH Part # AL8704N More Info Refer to Application Notices B103 and B111 * Non-stock item--shipping delayed up to 4 business days $127.89 $0.00 $127.89 Add to Cart REMY Part # 91510 More Info {Remy Gold} 105 Amps * Non-stock item--shipping delayed up to 2 business days PART NUMERS DO NOT MATCH... But are close matches. The only difference between the alternators is the rear snap on plastic casing. Anecdotal evidence: I once got an alternator for a 3100 from a junkyard, pulled off the shelf. It was the correct alternator, except for having a incorrect rear plastic shell. That alt had a cooling duct. It was from an LQ1. MATCH CONFIRMED. Quote
supersniperkilla Posted January 21, 2010 Author Report Posted January 21, 2010 i am not sure when the 3.1 motors stopped in production ...the alternator is off craigs list and the guy just says 3.1L He does not specify whether 3.1 or 3100 Quote
supersniperkilla Posted January 21, 2010 Author Report Posted January 21, 2010 the only thing he says is that it is from 1999 Quote
Crazy K Posted January 21, 2010 Report Posted January 21, 2010 the only thing he says is that it is from 1999 what make and model???? Quote
supersniperkilla Posted January 21, 2010 Author Report Posted January 21, 2010 i called the guy and he said its from a 1999 montecarlo 3.1.... i did more searching and found that those are 3100 cars... so in theory if i just turn it around like people are saying, it shall work not? Quote
Crazy K Posted January 21, 2010 Report Posted January 21, 2010 i called the guy and he said its from a 1999 montecarlo 3.1.... i did more searching and found that those are 3100 cars... so in theory if i just turn it around like people are saying, it shall work not? DO NOT ASSUME. later model 3100s have a different bracket, such as the 02 GP broken in my driveway... but the 99 monte carlo has the same style as a 95 Cs... so that is safe to say... No ear rotation is needed. only the rear plastic cover would need changing, if the basic alternator is correct. If the pulley is a different size, you could change the pulley, or belt to match. 1999 CHEVROLET MONTE CARLO 3.1L 189cid V6 FI (M) : Electrical : Alternator Price Core Total AdviceBBB PRECISION Part # N82223 More Info Std; Amps: 100 $100.89 $0.00 $100.89 Add to Cart NSA Part # ALT1413 More Info Std; Amps: 100 - Stocked in outlying warehouse--shipping delayed up to 1 business day Part Image $102.79 $0.00 $102.79 Add to Cart BBB PRECISION Part # 82223 More Info {Remanufactured ALTERNATOR} Std; Amps: 100 $79.79 $36.00 $115.79 Add to Cart BECK/ARNLEY Part # 1866316 More Info {May Not Include Pulley} Alternator, Remanufactured, 105 Amperes;Serpentine 6 Groove;1 Per Car (Only 2 Remaining) Part Image $102.79 $40.00 $142.79 Add to Cart REMY Part # 91502 More Info {Remy Gold} 100/105 Amps Part Image $166.79 $0.00 $166.79 Add to Cart ACDELCO Part # 3342466A More Info {#88864270} GENERATOR,(REMAN) WITH NEW REGULATOR; 2 DOORS; DELCO CS130D; 105 AMPS $154.79 $15.00 $169.79 Add to Cart BOSCH Part # AL8716X More Info {Remanufactured Alternator - May Not Include Pulley} Refer to Application Notices B103 and B111 Part Image $121.79 $55.00 $176.79 Add to Cart REMY Part # 20121 More Info {Reman} 105 Amps Part Image $135.79 $50.00 $185.79 Add to Cart DENSO Part # 2105114 More Info {Remanufactured} LS * Non-stock item--shipping delayed up to 2 business days looks like different part numbers from a 95 3100... But the images appear similar: 95 CS 3.4 Remy 21031 Remy 91510 95 CS 3100 Remy 21126 Remy 91522 99 MC 3100 Remy 20121 Remy 91502 Quote
supersniperkilla Posted January 21, 2010 Author Report Posted January 21, 2010 its just that i dont feel like shelling out over $100 for an alternator specificly for the DOHC Quote
GOT2B GM Posted January 21, 2010 Report Posted January 21, 2010 I'd sell you a new Delphi unit for the 94-97 LQ1 for $60 USD shipped Quote
