kwik-6 Posted January 17, 2010 Report Posted January 17, 2010 I tried to search the forum, but could not find any suggestions on aftermarket air intake kits for a 3400. Mine is a 94 cutlass vert. Any and all ideas / suppliers would be appreciated. Quote
xtremerevolution Posted January 17, 2010 Report Posted January 17, 2010 I tried to search the forum, but could not find any suggestions on aftermarket air intake kits for a 3400. Mine is a 94 cutlass vert. Any and all ideas / suppliers would be appreciated. You don't have the 3400, you have the 3.4L DOHC LQ1. The 3400 is a different engine. As for intakes, you can make one yourself fairly easily. Quote
jeremy Posted January 17, 2010 Report Posted January 17, 2010 making one is probably the most cost effective, but you do not want to go that route check out the link below.... he is a member here too, SN is "dohc v6" http://www.overkillengineeringmotorsports.com/9195wbodycai.html Quote
kwik-6 Posted January 17, 2010 Author Report Posted January 17, 2010 thanks... wasn't thinking... knew it was the DOHC... newbie error in using the wrong terminology Quote
