jake91 Posted January 13, 2010 Report Posted January 13, 2010 okay so im looking for new tires i would like to get a 235/55/16 but i cant find many. my budget is small. less than 100 a tire if i cant find any this size i will just go with fuzion zri 225/60/16. unless anyone knows of a better tire than the zri for less than 100 each
Crazy K Posted January 13, 2010 Report Posted January 13, 2010 Yout budget does not reflect reality. 235/55R16 tires are expensive. be happy with some good 225/60R16. how much are the the fuzions in that size?
Rdrckt_92 Posted January 13, 2010 Report Posted January 13, 2010 I had those on my 17s and I loved them, IIRC I only paid around 70 each on tirerack
jrcuttymann Posted January 13, 2010 Report Posted January 13, 2010 http://www.tirerack.com/tires/TireSearchResults.jsp?width=235%2F&ratio=55&diameter=16&manufacturer=General&startIndex=0&search=true&pagelen=20&pagenum=1&pagemark=1&x=25&y=16 General Altimax HP, I've heard some good things about these tires. General is now owned by Continental which is a fine tire also more expensive. I know you said under $100/tire but these are $108
jake91 Posted January 13, 2010 Author Report Posted January 13, 2010 i can get the fuzions for 500 mounted and balanced
jake91 Posted January 13, 2010 Author Report Posted January 13, 2010 and forget my original question im going with the fuzions
jake91 Posted January 14, 2010 Author Report Posted January 14, 2010 can i fit a 245 on a cs 5 spoke or will it rub
jake91 Posted January 14, 2010 Author Report Posted January 14, 2010 never mind i did some research on my own
3.1cutlass Posted January 14, 2010 Report Posted January 14, 2010 can i fit a 245 on a cs 5 spoke or will it rub It is too wide for the rim.
Andrew Posted January 15, 2010 Report Posted January 15, 2010 just stick with 225's. Adding a centimeter or 2 in width wont do anything noticeable for traction. Not to mention, 225's are cheaper.
Crazy K Posted January 15, 2010 Report Posted January 15, 2010 just stick with 225's. Adding a centimeter or 2 in width wont do anything noticeable for traction. Not to mention, 225's are cheaper. ding ding ding.
jake91 Posted January 15, 2010 Author Report Posted January 15, 2010 well i strayed away from the fuzions the guy at the tire shop told me that the zri out here dr rot after 20k out here so he talked me into a set of falkens they are real nice and he cut me a good deal for only 400 mounted and balanced
Andrew Posted January 15, 2010 Report Posted January 15, 2010 thats too bad. he just unloaded some crap on you. lemme guess, ze-512.
jake91 Posted January 15, 2010 Author Report Posted January 15, 2010 yep whats bad about them? i havent bought them yet
jake91 Posted January 15, 2010 Author Report Posted January 15, 2010 though i probably will because i read a bunch of good/decent reveiws on them. i drive a stock cutlass not a autocross car, they will only be on the car for a little over a year, and they are only $400
mediabandit Posted January 15, 2010 Report Posted January 15, 2010 I am running Falken ZE 912's on the Z34 and have had no problems with them at all, i like them more then the Pirelli's P-Zero's i had on it. Lots of grip, won't break free on hard turns and are half decent in the rain. I run 235/50/17 .
Crazy K Posted January 15, 2010 Report Posted January 15, 2010 if it is only for a year... have you considered getting used tires installed????
jake91 Posted January 15, 2010 Author Report Posted January 15, 2010 if it is only for a year... have you considered getting used tires installed???? i want new
jake91 Posted January 15, 2010 Author Report Posted January 15, 2010 Ugh... I hated my Falken 512's. why? no one will give me an answer
slick Posted January 15, 2010 Report Posted January 15, 2010 Ugh... I hated my Falken 512's. why? no one will give me an answer Loud, didn't grip worth a damn, horrible in anything wet, wear was insane (2 summers and I needed replacements!).
jake91 Posted January 16, 2010 Author Report Posted January 16, 2010 well i went ahead and ignored you guys, but i like the new tires when i floor the car it doesnt spin anymore and they really hold corners well before i went into a corner at 45 scared when the tire let loose and now i can hit the same corner at 45 and hear a small squeel but i fell confident i can go faster and they are quite anand privide a very nice ride so mabey im just lucky and as for treadwear im noy worried im only going to be driving it for a year with these then they become track tires
Andrew Posted January 16, 2010 Report Posted January 16, 2010 wow. you forgot how to punctuate all the sudden. they will last you a year fine, but they do wear stupid fast. EVERYONE i know that has bought them said this very thing.
