Sagitarii Posted January 6, 2010 Report Posted January 6, 2010 Alright, I am going to have to change some bulbs in the cluster. How is the bezel removed ? ? There seems to be clips on the top side. Are there screws underneath ? ? What bulb type is the illumination ?? thanx Quote
Crazy K Posted January 6, 2010 Report Posted January 6, 2010 remove 4 7mm bolts holding kick panel in place. remove 4 7mm bolts holding metal thing under column in place. loosen the four 13mm bolts at the top and base of the column. turn out maybe 1/2 inch. remove the two bolts and the top and lower the column. be cautious if you have a column shift to not damge the shift indicator. pull out on the cluster bezel. remove two 7mm bolts holding top of cluster in place. unhook cluster plug.. flathead screwdriver helps pop the two rubber pegs at the bottom of cluster off... and out it comes, unless... if you have a column shift you must disconnect the indicator as you pull it out. Quote
