I know parts of this have been asked, but I am from Montana ..
Where men are men, women are few and sheep are nervous... so bear with me.
Will the Bonneville X laces fit my 96 Cutty ? I don't want to screw around with spacers and studs.
What about later model Bonne/Buick/GP wheels. Do the 17/18 inch wheels fit ?
I'm on a limited budget, I'll need to do tires this spring.
Hell, I might end up on the Wrong Wheels discussion
only if you remove all the brake hardware.
(NO!)
some of those rims can be added with spacers. refer to what GOT2BGM did to stick monte/lumina SS rims on his first gen Z34.
1" bolt on spacers all around works perfect
bonnieville xlaces fit without an issue
on a GEN 1 car?
The bonneville xlaces will not clear the front calipers without using a spacer on a first gen. I've test fitted on my '93 Grand Prix before. I forget what size spacer would be needed...
what size of spacers ? will they require new studs ? ? :willynilly:
you SHOULD investigate adapter rings; they bolt onto the studs, and have an additional set of studs attached to them that use a second lugnut set.
again... this is what GOT2B GM did.
