Crimson Fury Z Posted December 29, 2009 Report Posted December 29, 2009 i've dealt with this for not quite a year, but here is the issue; it only defrosts 1/2 of the window. on each side theres is the wire that runs to a metal piece that heats the small lines. one side has come off the window. whats a good way to reattach it? Quote
94 olds vert Posted December 29, 2009 Report Posted December 29, 2009 Solder it. I think the factory solder them. Quote
jeremy Posted December 29, 2009 Report Posted December 29, 2009 there are defroster repair kits at most auto parts stores....can be used to reattach broken tabs and repair breaks in any of the lines Quote
carkhz316 Posted December 29, 2009 Report Posted December 29, 2009 ^What they said, except with the lines, if there's a break, don't use the little stencil they give you. It's way too wide. You a couple strips of masking tape instead. Quote
Andrew Posted December 31, 2009 Report Posted December 31, 2009 there are defroster repair kits at most auto parts stores....can be used to reattach broken tabs and repair breaks in any of the lines and make sure you follow the directions to a T. ie the air temp has to be just right. Quote
3pt1lumina Posted December 31, 2009 Report Posted December 31, 2009 Had to do it 2x on my grandfather's 99 Lumina.... yes follow the directions TO A TEE. It's not hard but annoying when you have to do it more than once. Quote
chevyguy8893 Posted December 31, 2009 Report Posted December 31, 2009 Both soldering and the repair kits work well. I prefer to solder as long as there is still something on the window to solder to, if not I use the kit. Soldering is just cheaper if you already have a soldering gun. Quote
