Brandon72 Posted December 28, 2009 Report Posted December 28, 2009 Going to junk yard today to get a new turn signal lever for my 93 GP. Can it be removed with pulling the steering wheel? Thanks, Brandon Quote
94 olds vert Posted December 28, 2009 Report Posted December 28, 2009 Nope, I think the wheel needs to be pulled. You have a steering wheel puller? Quote
Crazy K Posted December 28, 2009 Report Posted December 28, 2009 lever only? or complete switch? on a gen 1 car, the lever comes off with a yank. Quote
94 olds vert Posted December 28, 2009 Report Posted December 28, 2009 If you want the entire switch, then the wheel needs to be pulled. Quote
cutty Posted December 28, 2009 Report Posted December 28, 2009 If you want the entire switch, then the wheel needs to be pulled. Yes the wheel does need to come off for the entire switch, and if you need you can get a cheap and good wheel puller at harbor freight. Quote
Brandon72 Posted December 28, 2009 Author Report Posted December 28, 2009 I just need the lever only. The lever just pulls right out? I meant to say "Can it be removed without the puller?" Quote
cutty Posted December 28, 2009 Report Posted December 28, 2009 I just need the lever only. The lever just pulls right out? yes just like Ken said, it will pull straight out with a hard pull. Quote
