rockfangd Posted December 25, 2009 Report Posted December 25, 2009 (edited) The BLUE connector is C1. Wire A = a RED wire. Connect it to an ORANGE wire thatis HOT ALL OF THE TIME. (I connected mine to theORANGE wire that gives power to the cigarette lighter,but it is recommended that you connect it to the ELEC.Fuse #2 constant +12V (top row, middle fuse).) Wire B = PINK/BLACK. Connect it to a wire that is HOTIN RUN. (I connected mine to one of the PINK/BLACKwire in my dash, but it is recommended that youconnect it to CLUST. Fuse #9 switched +12V (3rd row,far right).) Wire C = BROWN. Connect it to the light on input. Inmy car I have a YELLOW wire in slot C10 but I thinkthat that is exclusive to the digi-dash. I want to soythat there should be a YELLOW wire coming out of theheadlight switch that should work. I know that on mydash, when the lights are on, and the display is atMAX, then it has no power in the wire, but when Iadjust the lever down, the wire becomes hot, and dimssteadily. I use a tester that is just a screwdriverlooking thing that has a point at one end, and analligator clip that you hook up to ground. Wire D = GREY. Connect this to one of the grey wirefor illumination. I hooked mine up to the GREY wirethat lights up the bulb for the cigarette lighterlight. Wire E = BLACK/WHITE. This is a ground. Wire F = BLACK/GREY. This wire is not used. Wire G = YELLOW. Connect this wire to the LITE BLUEwire in the dash (You may not have this wire). This isyour English/metric wire. In my car, I push a buttonon the dash to change it from English (MPH) to metric(KPH). When this wire is hooked up, it automaticallychanges the DIC display from one to the other when theE/M button is pushed on the dash. This is a wire thatis not necessary for the DIC to function, so if you donot have the wire, then just leave it unconnected. Wire H = BLACK. This is a ground. I hooked this up tothe BLACK wire connected to the cigarette lighterlight. The BLACK connector is C2. Wire A is ORANGE. Connect this to the ORANGE wirecoming out of the ALDL connector under your dash. Thisis your SERIAL DATA INPUT where the DIC will get theinfo for your gauges button. Wire B = DARK GREEN. Connect this to the DARK GREENwire in the dash. This is your Vehicle Speed Input. Inmy car it is wire number D15. Wire C = PINK. Connect this one to the PURPLE wire inthe dash. This is your vehicle Fuel sender wire. In mycar it is wire number D13. Wire D = BLACK/GREEN. This is another GROUND. It isnot used in the 91 model. Driver Info System was not available 92+. You will not find a new cutlass with one. If you putone in your car, then it will go where the storagecubbyhole is under the ashtray. The screw-holes forthe 98 Regency’s DIC is identical the Cutlasses, so itwill go there with no problem. If you get the DIC outof a Cutlass, then be sure to get the storage pocketas well. IF (OR WHEN) you get the HUD, then thecontrol switch will go where the storage is. 89-90cars got a little pocket in the empty space. HUDcontrol panel was mounted above the headlight switch(below the dash pad).91 cars got a little pocket if they didn't have HUD.Cars with HUD got the control panel instead of thepocket. Is your headlight switch up high next to thespeedometer with the foglight switch next to the airvent? If so, then the HUD switch goes in the pocket.My car headlight switch is located next to the vent,with the foglight switch next to the speedo. (INT'Lmodels also had the BASS BOOST switch as well as thefoglight switch) But I will still put the HUD switchnext to the DIC. Edited July 12, 2017 by digitaloutsider Fixed formatting. Quote
ManicMechanic Posted December 25, 2009 Report Posted December 25, 2009 FWIW, only 27 1991 Cutlass Supremes got both HUD and DIS. Quote
94 olds vert Posted February 23, 2017 Report Posted February 23, 2017 INSTRUCTIONS: Oldsmobile Driver Information System: *not responsible for errors during installation such as damaged DICs, car fires, house fires, total city fire, end of universe due to division by zero through the following of the info provided* The Driver Information System is used on several Oldsmobile model lines. This includes A, G, H, L, N, and W-bodies of the 88-91 era. All units are physically identical, but have some internal programming differences. Wiring colors can vary greatly, so verify all wires by placement. This unit has a pigtail on the rear, and colors on the pigtail differ from colors within the vehicle wiring harness. DIS C1=blue 8 cavity connector connector pin# color(unit) color(vehicle) function DIS-C1-A RED ORN constant hot, memory (+) DIS-C1-B PNK/BLK PNK/BLK switched ignition feed, hot in run (+) DIS-C1-C BRN BRN or GRN or YEL VF dimming input (+) DIS-C1-D GRY GRY Illumination (adjustable backlighting) DIS-C1-E BLK/WHT BLK/WHT ground (-) DIS-C1-F* BLK/GRY not present --- DIS-C1-G$ YEL not present or BLU E/M input DIS-C1-H BLK BLK/wht(or BLK) ground DIS C2=black 4 cavity connector connector pin# color(unit) color(vehicle) function DIS-C2-A ORN ORN SERIAL DATA INPUT DIS-C2-B DK GRN DK GRN VSS/speedometer input DIS-C2-C PNK PPL fuel level sender input DIS-C2-D% BLK/GRN not used or BLK ground for e/m circuit(-) * all vehicles examined omit connection to this wire, even though it is present on the unit pigtail $ not necessary to be hooked up. most vehicles examined omit this wire. % only hooked up on vehicles if equipped with an E/M input and what they do: DIS-C1-A Constant hot source, it is power for the DIS memory. Digital clusters would have this wire, but if your car does not have a digital cluster, the radio will have a constant hot wire for it's memory that would be a good power source. DIS-C1-B Switched ignition feed, hot in run. it powers up the unit when you start the car. You can tie this to the cluster or radio. both have a hot in run wire. DIS-C1-C Vacuum fluorescent dimming input. It controls the digital display intensity. you can tie this to a VF wire. DIS-C1-D Button Illumination (adjustable backlighting)". You can hook these to the backlighting for the cluster or radio. DIS-C1-E Ground. DIS-C1-F Not used and not defined DIS-C1-G English/Metric input, externally set by cluster or switch to set DIC unit mode, if wired. DIS-C1-H Ground. DIS-C2-A SERIAL DATA INPUT, which the DIC gets info from the ecm/pcm for calculations and display. DIS-C2-B VSS signal input. this can be hooked to the cluster feed for the speedometer. DIS-C2-C Fuel level gage input. this can be hooked to the cluster feed for the fuel gauge. DIS-C2-D Ground, connected only if E/M input is present(without regard to mode) 1992 analog UB3 CS cluster connector Pin# Wire color function aUB3-C1 TAN/WHT brake indicator aUB3-C2 WHT tachometer input aUB3-C3 GRY illumination (adjustable backlighting) (+) aUB3-C4 PPL fuel level sender input aUB3-C5 DK GRN VSS speedometer input aUB3-C6 YEL not used, VF display dim enable (+ to enable dimming) aUB3-C7 BRN/WHT not used, VF dimmer input aUB3-C8 ORN not used, ELEC FUSE circuit, constant hot, memory (+) aUB3-C9 --- not used aUB3-C10 BLK ground aUB3-C11 --- not used aUB3-C12 --- not used aUB3-C13 PNK/BLK CLUSTER FUSE circuit, Hot in run (+) aUB3-C14 --- not used aUB3-C15 PNK/BLK INDICATOR FUSE circuit, hot in run, bulb test, and start (+) aUB3-C16 DK GRN coolant temperature sensor input connector Pin# Wire color function aUB3-D1 --- not used aUB3-D2 BRN Check Gauges output to HUD unit aUB3-D3 TAN/BLK shift indicator (if equipped) aUB3-D4 LT BLU left turn indicator (+) aUB3-D5 LT GRN high beam indicator (+) aUB3-D6 DK BLU right turn indicator (+) aUB3-D7 BLK ground aUB3-D8 YEL fasten seatbelt indicator aUB3-D9 --- not used aUB3-D10 --- not used aUB3-D11 TAN oil pressure input aUB3-D12 --- not used aUB3-D13 LTGRN/BLK "Antilock" indicator aUB3-D14 YEL/BLK "low coolant" level indicator aUB3-D15 BRN charge indicator feed (sets check gauges indicator) aUB3-D16 BRN/WHT "Service Engine Soon indicator different pinouts existbetween 92-93 and 94 analog cluster, you cannot substitute a 92-93 cluster for a 94 without loosing these critical indicators. Wire decoding, CS DIS to 92 CS analog cluster. DIS connector C1=blue 8 cavity connector connector pin# color(unit) color(vehicle) function DIS-C1-A RED ORN constant hot, memory (+) aUB3-C8 ORN not used, ELEC FUSE circuit, constant hot, memory (+) or Radio-C1-10 ORN constant hot, memory (+) DIS-C1-B PNK/BLK PNK/BLK switched ignition feed, hot in run (+) aUB3-C13 PNK/BLK CLUSTER FUSE circuit, Hot in run (+) DIS-C1-C BRN BRN or GRN or YEL VF dimming input (+) aUB3-C7 BRN/WHT not used, VF dimmer input or Radio-C1-7 BRN/WHT VF dimming input (+) DIS-C1-D GRY GRY Illumination (adjustable??? backlighting) aUB3-C3 GRY illumination (adjustable backlighting) (+) DIS-C1-E BLK/WHT BLK/WHT ground (-) ground to chassis or other ground DIS-C1-F* BLK/GRY not present --- *not used, do not connect DIS-C1-G YEL not present or BLU E/M input HUD LT BLU E/M wire DIS-C1-H BLK BLK/wht(or BLK) ground ground to chassis or other ground DIS connector C2=black 4 cavity connector connector pin# color(unit) color(vehicle) function DIS-C2-A ORN ORN SERIAL DATA INPUT aldl ORN ALDL data wire DIS-C2-B DK GRN DK GRN VSS/speedometer input aUB3-C5 DK GRN VSS speedometer input DIS-C2-C PNK PPL fuel level sender input aUB3-C4 PPL fuel level sender input DIS-C2-D BLK/GRN not used(except if e/m equipped)BLK ground (-) ground to chassis or other ground 5stevo4 1 Quote
sean1991olds Posted March 16, 2018 Report Posted March 16, 2018 I want to add some pictures to this thread... I got this DIS from ebay and when I got it I heard rattling.. thinking and wondering if it was electrical components or solder or something that could cause a short... I opened it up. And in doing so, lots of 90s era plastic broke. BUT, figured this might be nice/useful for people to see. Inside view of front of display, here you see the buttons - and broken plastic Front display: Inside: More internals: My efforts to protect the 2 PCB's from touching: NASTY crack... of course this happened: Otherwise looks great: Taped up on the outside too.. and gap toothed as that part broke off: Broken pieces of my heart 94 olds vert 1 Quote
jiggity76 Posted March 16, 2018 Report Posted March 16, 2018 That's a bummer. I'm also going to attempt putting a DIS in my Cutlass this summer so maybe we could help each other out with the help of the other guys. I don't know anything about wiring stuff at all. My car is suppose to have been prewired for the DIS but having a tough time finding it. I'm going to pull the radio out again and see if I can find it in the jumbled mess of wires. sean1991olds 1 Quote
jimmyfloyd Posted March 16, 2018 Report Posted March 16, 2018 Did you check to make sure non of the capacitors were bulging when you had it apart? They look ok from the pictures, but always good to check. sean1991olds 1 Quote
sean1991olds Posted March 16, 2018 Report Posted March 16, 2018 Yeah, that was one of the first things I looked at - they looked ok! Working in the IT service field I've seen many motherboards with bad caps.. and I have people say.. but it should still work right? And then I say, you see this component right here.. looking like that.. it no longer can do what it was supposed to do.. so many toasted ECS and AsRock motherboards back in the early 2000's (other brands too). Did you check to make sure non of the capacitors were bulging when you had it apart? They look ok from the pictures, but always good to check. Quote
Imp558 Posted March 16, 2018 Report Posted March 16, 2018 If you give me some specific years I'd be happy to post schematics and pinouts. Quote
92InternationalCoupe Posted March 31, 2019 Report Posted March 31, 2019 I can't argue with that Quote
