Vacuum routing, anyone with a 91-95 3.4 TDC who can check theirs?
If you've got a 91-95 3.4 TDC, can you take a look at your vacuum check valve - it's a little black plastic cylinder below the cruise control servo, or to the right of the battery (positive terminal side) with three vacuum ports on it. Looks like this.
You'll probably have to take the airbox out to see it. I'm interested in where the hose that goes sideways connects. The service manual diagram makes it look like it connects back to the other side of the valve on a T-connector, but also says it goes to HVAC. Where does it go on your car?
Thanks
My car doesnt have that... But I know at one time it did... I believe the one going sideways goes down into the vacuum ball located behind the front bumper in front of the drivers wheel
