2regals Posted December 24, 2009 Report Posted December 24, 2009 I have been having problems with my gauge cluster on my 92 Regal, it has the digital speedometer. What needs to be done to swap in a full analog gauge cluster? Quote
2regals Posted December 25, 2009 Author Report Posted December 25, 2009 I can get a cluster for 20 bucks and imwondering if its worth it. Quote
Crazy K Posted December 28, 2009 Report Posted December 28, 2009 we need pinouts to complete your suggested task. and yes. it can be done. but pinouts will be needed. APB request: 1992 regal digital cluster pinouts 1992 regal analog cluster pinouts. Quote
Crazy K Posted December 28, 2009 Report Posted December 28, 2009 THANKS ROBERT! ok... as for the j/y cluster.... If you get a j/y cluster I suggest you get the cluster, the lens insert in front of the cluster, and at least 1 foot of the donor car's wiring harness. It is IMPORTANT that you get the harness connector, which allows you to install it in your car. BEST ADVICE: Print out the wiring info and take it with you to the yard to get the donor cluster. Make sure it matches the donor car before you buy!!! If it does not, you need to record the donor car's year, make, model, and engine, and get back to us. You should probably record the wiring diagram from the donor car plug so we can find you the diagram. Quote
3pt1lumina Posted December 31, 2009 Report Posted December 31, 2009 I have a cluster from a 93 with temp/tach/oil psi/ that is analog. I think the harness is with it too I can't remember. If the one you have doesn't work, I'll sell....fyi. Quote
