5speedz34 Posted December 17, 2009 Report Posted December 17, 2009 I found this thread: http://www.w-body.com/forum/index.php?topic=53840.0 you will need to connect positive power to the pink/black and the orange in terminal D16 and then ground to the black and the black/white wires Could someone elaborate on this post? I need to find out the miles on this cluster to verify the miles on my transmission that I just pulled. The post joey b made is slightly confusing since I don't have a black/white wire. I can post pics if necessary. Quote
Crazy K Posted December 17, 2009 Report Posted December 17, 2009 1990 digital UB3 CS cluster connector Pin# Wire color function dUB3-C1 PNK/BLK INDICator FUSE circuit, hot in run, bulb test, and start (+) dUB3-C2 LT BLU left turn indicator (+) dUB3-C3 DK BLU right turn indicator (+) dUB3-C4 TAN/WHT brake indicator (-) dUB3-C5 GRY/WHT "Antilock" indicator dUB3-C6 TAN/BLK shift indicator (-) dUB3-C7 LT GRN high beam indicator (+) dUB3-C8 --- not used dUB3-C9 --- not used dUB3-C10 YEL VF display dim enable (+ to enable dimming) dUB3-C11 GRY Illumination (adjustable backlighting) (+) dUB3-C12 --- not used dUB3-C13 ORN Serial data link to aldl (for tach and data) dUB3-C14 BLK.WHT ground dUB3-C15 --- not used dUB3-C16 PNK/BLK CLUSTER FUSE circuit hot in run (+) connector Pin# Wire color function dUB3-D1 BLK ground for indicator bulbs dUB3-D2 YEL fasten seatbelt indicator dUB3-D3 YEL/BLK "low coolant" level indicator dUB3-D4 BRN "charge indicator" dUB3-D5 BRN/WHT "service Engine Soon" indicator dUB3-D6 --- not used dUB3-D7 --- not used dUB3-D8 --- not used dUB3-D9 LT/BLU english metric switch ouput(switch part of cluster) dUB3-D10 BRN/WHT VF dimmer input dUB3-D11 TAN oil pressure sensor input dUB3-D12 DK GRN/WHT coolant temperature sensor input dUB3-D13 PPL fuel level sender input dUB3-D14 --- not used dUB3-D15 DK GRN VSS speedometer input dUB3-D16 ORN ELEC FUSE circuit, constant hot, cluster memory (+) tony. the grounds CAN vary in the exact color.... but here is the pinouts. Those are the hots and grounds for the cluster. Quote
